Test pipe required?
Originally Posted by Little_AP1_S2K,Jul 5 2010, 12:04 PM
test pipe on my n1 sounded way to raspy
+1 on the loud factor, it will be too loud for music once installed. Give it maybe a thousand or so miles to get a carbon build up and it will have a more defined tone.
It gets nasty loud at wot, cops will definitely know your around if you show boat.
I've learned its db range is loud on the low end if you gas it, around 3500 it gets quiet up until 5K.. the rest is.. you know....
I take advantage of any road that has a structure of some kind covering all sides except the one in front and behind you.. It is pure
I DD on this exhaust with TP also. Its something you will get use to..
i have an invidia tp with cel fix 110.00 shipped and im using a berk tp with a custome 1 off exhaust system mig & tig welded, powder coated with high temp powder coat and finished off with an Apex n1 muffler with the same powder coat treatment. Gotta say wow~!~!~!~!!!! i havent heard a bike or car that tops the drone and loudness of this system along with burps of smoke n flames!!
