S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Valve Adjustment for performance
Old Jun 16, 2011 | 09:03 PM
doser703's Avatar
Default Valve Adjustment for performance
What up guys so am planning to do a Valve Adjustment this weekend i just wanted to know witch Size Feeler Gauges should i use as far as performance goes any inputs well help thanks.....
Old Jun 17, 2011 | 07:03 AM
SLINKYDOG's Avatar
.21-.25mm intake
.25-.30mm exhaust
loose is low end power
tight is top end power
Old Jun 17, 2011 | 07:27 AM
wadzii's Avatar
Banned
running looser results in less duration/overlap and has a similar effect as retarding the cam timing
running tighter results in more duration/overlap and has a similar effect as advancing the cam timing.
I run mine 0.002 tighter than stock.. the ass dyno didnt really notice much difference.. it seemed better at high rpms w/no change at lower rpms. You arent going to notice much difference changing it 1-2 thou.
Old Jul 22, 2011 | 01:12 PM
Gernby's Avatar
Former Sponsor
Originally Posted by SLINKYDOG
.21-.25mm intake
.25-.30mm exhaust
I strongly disagree about loose valves increasing low end power. That might be the case on non-VTEC motors, but you lose a LOT of low end when you go loose on a VTEC setup. The impact is pretty small on the high cam. I know this because I did my first valve adjustment incorrectly, and measured the gap between the cam lobe and roller rocker, which resulted in clearances that were about .005" larger than spec. This gave me a huge VTEC kick, so I thought it actually increased performance. However, when we had an S2000 club dyno day, I have very poor low cam performance, but my high cam performance was 2nd from the best out of the group. I later noticed that the valve clearance is supposed to be measured between the valve and adjuster screw, so I checked them again, and discovered how loose they were. I reduced the clearances back to spec, and went back to the dyno. The improvement in the low cam was something like10 ft-lbs, but there was practically no gain above VTEC.
Old Aug 25, 2011 | 10:59 PM
etang789's Avatar
I have performed 2 different valve adjustments on 2 different S2000.
I like the 0.007 and 0.009 setting more, which is 0.001 tigher than factory suggested spec. With this setting the car feels much more solid.
Old Aug 28, 2011 | 08:25 AM
08s2000CRbackinblack's Avatar
whooo thats sounds tight!!!! i didnt know that tight was possible??? i run . 010 and .015
Old Aug 29, 2011 | 08:38 AM
Gernby's Avatar
Former Sponsor
If you are setting your intake clearances at .010, then that's on the loose side of OEM spec, but if you are setting your exhaust at .015, then you are significantly outside of spec, loosing power, and are increasing wear on the valve train. Large clearances increase the force of impact between the cam lobe and roller rockers, which is why valve noise increases with clearances.
I've been running clearances .001 - .002 below spec for a combined ~100K miles in my 2 S2000's with good results.
Old Aug 29, 2011 | 10:38 AM
im sorry i was mistaken i went and looked at which feeler gauges i had bent, .20mm and .25mm. you scared me for a second
Cali2K
Aug 16, 2013 10:18 PM
neuweiler
Mar 19, 2008 02:19 PM
S2kMY05_Berlina
Oct 2, 2007 10:24 AM
WindchaserS2K
Aug 30, 2007 12:13 AM
Destiny2002
Dec 25, 2003 04:01 PM
