2015 NASA TT Setup
Yep, having the car setup for a wing and then removing it is going to be a recipe for oversteer (as the Lotus guys found out). This why I would use the points from the wing to run an adjustable FSB to dial it out.
Originally Posted by Beyond_Redline' timestamp='1426094882' post='23536018
Kyle, if you take your wing off on the roval, ditch your splitter with it. You're running a square tire setup right? should be enough to get it to turn in. Id just set the wing at 0.
Now, whether that's worth the drag of even the trimmed out wing is still up for discussion, and the bar still may be the ticket on super highspeed tracks as long as the car itself isn't producing back end lift at those speeds.
Most of the wing mounts I've seen do a horrible job at accounting for the fact that the wing is positioned behind the cabin. Take the APR wings, for example. With their twisted cord, true 0 AoA (measured to the airflow) is more like when the outside sections are flat to the ground, not the inside section. I don't think the stock GTC-200 or 300 S2000 mounts get you anywhere near this. And with the camber on the wing, it will still make downforce even at true 0 AoA.
FWIW, the car which had the best time at the Speedway in the class for the weekend was a wingless S2000 (who is on the forums if he sees this thread).
245 seems to be the norm as far tire size for TTB. I know that the fastest setup on the BRZ/FRS, which is pretty much the same weight, was 225's after playing with various options in the R compound options. Anyone else drop tire size to free up mod points in TTB? This would give me enough to do front and rear aero and some other items. Only downside I can think of other than loss of overall contact patch would be heat capacity and being less forgiving with over aggressive driving.
It really comes down to building the car around the tire compound and size you desire to run.
225 R7s are zero points on a TTB base class reclass. They are also a bit wider vs a 225 A6. I definitely felt a difference going from a 245 to a 225, but I think I found a good solution to gain some width back when running a 225.
@WynnS123 I said " I think" I've found a solution haha. It was somewhat confirmed at my last event but I will be able to truly confirm it at Texas World Speedway in about 3 weeks. (Hint: it is something SCCA limits where NASA does not)
Car wont be painted till next week so I probably wont have time to prep for TWS.
