2015 NASA TT Setup
Old Jan 20, 2015 | 06:12 AM
  #51
s2000ellier's Avatar
Do the rules state the BTM whp for each model? That would be great to know before hand.
Old Jan 20, 2015 | 06:14 AM
  #52
King Tut's Avatar
What is BTM whp?
Old Jan 20, 2015 | 06:15 AM
  #53
base model trim wheel horse power,
you said 215 is greater than a F22 at 2850. I thought maybe there was a table that says what a F22 makes, or any model for that fact.
Old Jan 20, 2015 | 06:22 AM
  #54
King Tut's Avatar
I believe Greg studies each car and keeps a database of stock whp dyno figures for cars that he gives a dyno reclass to. I would think at this point the Dynojet whp of a stock F20 and F22 has been pretty well established.
Old Jan 20, 2015 | 06:24 AM
  #55
Well Dyno numbers that i've seen are pretty wide in range from one to another. I think if anything they are least consistent thing lol
Old Jan 20, 2015 | 06:28 AM
  #56
King Tut's Avatar
Properly performed Dynojet runs should be within 1% from dyno to dyno, and that is why NASA uses it as their standard. If you can find a Dynojet that seems to read lower, then by all means go dyno your car there before you submit your dyno forms for your reclass.
Old Jan 20, 2015 | 07:22 AM
  #57
Mahjik's Avatar
Sure but its not like the weight he assigns will be 3000+ lbs, I imagine someone here can ballpark it based on their experience?
Currently the car is around 2900lbs
Greg has some formula only he knows about for the weight, so there is no good in trying to guess. It doesn't follow the published power to weight ratios for the classes as he has some sort of modifier. The best thing to do is to just get the dyno done as early as possible and send the data to Greg. Then just react to whatever weight he provides.
Old Jan 20, 2015 | 07:31 AM
  #58
aCab's Avatar
The reclass I ran at Nationals in 2012 and at some events in the 2013 season was 215hp @2770 lbs, TTC base class. If anything, he's added more weight to the cars since then to try and even them out. I haven't applied for a dyno reclass for this season yet.
Old Jan 20, 2015 | 08:40 AM
  #59
thanks yall
Old Jan 20, 2015 | 09:54 AM
  #60
ndogg's Avatar
I would guess 2775lbs is what you will get. Every S2000 TTC reclass I have seen has been between 12.8#/hp and 13.1#/hp. More #/hp the lighter the car is (or the less power it makes).
