adjusting shocks
Old Sep 24, 2008 | 05:22 AM
OnGrid's Avatar
Default adjusting shocks
All right, I have Koni adjustable shocks and stock springs and the rubber I have on are the Potenza RE-O1Rs. I do a lot of AutoX and also some HPDs on roadcourses. Does anyone know how firm/soft the shocks should be for those two activities? I assume fronts and rears wouldn't be adjusted the same amount. Thanks
Old Sep 24, 2008 | 01:28 PM
jyeung528's Avatar
i have mine set at 3/4 all around...
Old Sep 24, 2008 | 01:29 PM
jyeung528's Avatar
i assume you could set the rears a little softer.
Old Sep 24, 2008 | 01:55 PM
istdercollen's Avatar
I have the fronts wound all the way out and the rears at 1 1/4 turn stiff. I think there is a balance between the settings and your driving style. rear should be softer than the front generally speaking though.
Old Sep 24, 2008 | 05:20 PM
Zachreligious's Avatar
Turn them to "fast"
Really, there are too many variables, but if that's the only thing you have to adjust besides tire pressure, all you have to remember is the basics. I prefer the car to be pretty stiff, so I start with mine full stiff and then soften the end that loses grip first until the car is more neutral.
If you're talking about the OTS yellows (not revalved), and driving on stock springs and relatively smooth surfaces, this should give you a place to start.
Old Sep 25, 2008 | 04:31 PM
OnGrid's Avatar
Thanks for the tips everyone, I'll give it a try.
Old Sep 26, 2008 | 08:17 AM
alwaysinboost's Avatar
doesn't matter what you try, that EVO is still going to beat your pants off... that didn't sound gay did it?
Jerry_Attric
Sep 12, 2018 12:44 PM
Yknits18
Mar 15, 2018 03:19 PM
Mortlach
Apr 7, 2017 10:48 AM
Roku_F20C
Mar 11, 2003 09:37 PM
Sunder
Nov 11, 2002 09:53 PM
