AiM Solo DL
Old Nov 7, 2012 | 08:53 AM
GT Motoring's Avatar
Former Sponsor
Originally Posted by sheel
Originally Posted by GT Motoring II' timestamp='1352308304' post='22135645
[quote name='sheel' timestamp='1352306225' post='22135537']
[quote name='GT Motoring II' timestamp='1352304701' post='22135476']
Pretty good info over here by the way - http://www.trackhq.com/forums/f299/aim-solo-how-4526/
Thanks, yeah this was a starting point for me. In fact, I purchased the DL from RichardEVO on those boards.
The basic stuff is pretty simple, but not sure how to get the OBD data sampling setup. I think I read somewhere that for the s2000, you need to set it to ECU Manufacturer = OBDii and Model = ISO. Will have to try that out.
Hopefully its not like the E9x Bmws - those have to have an extra wire or two spliced into the harness.
[/quote]
Nope, that shouldn't be the case... those E92s use CAN I believe. I think it's simply a matter of configuration on the DL itself that I don't have correct. and then from there, I need to figure out how to use Race Studio. The basic GPS Speed graph and mapping is pretty straight forward, but from there...
[/quote]
I recently sold my Traqmate and will be picking up a Solo DL (or Solo) in the future - a few of the s2000/miata guys here in the MidWest are all getting the same unit so its easier for us to share data. I'll have ample time to go through the unit in about a month or so at Road Atlanta and Atlanta Motorsports Park - if you haven't solved your issue by then, I'll be able to be a resource at that point.
Be sure to post in here if you figure the correct settings out!
Old Nov 7, 2012 | 09:06 AM
sheel's Avatar
will you be at RA with NASA? 12/01-12/02?
Old Nov 7, 2012 | 02:10 PM
Former Sponsor
Most likely. If not there in the s2000 in TTC, at least there hanging out. I will for sure be driving at Atlanta Motorsports Park on Dec 2 - either in the s2000, miata, or a rental car.
Old Nov 7, 2012 | 02:39 PM
speedengineer's Avatar
Austin, I ordered my DL with the CAN cable not the OBDII cable, so we won't be able to plug it into your OBDII port to test.
Can't wait to test the unit out though and see how it does!
Old Nov 7, 2012 | 02:41 PM
Former Sponsor
That sounds a little dirty.
Old Nov 7, 2012 | 08:45 PM
Someone has a very imaginative mind - cause that doesn't sound dirty at all...
Old Nov 7, 2012 | 08:46 PM
sheel's Avatar
Awesome! I wanted to go but I won't be able to make it down there cause I'll be in Austin that weekend.
Old Nov 8, 2012 | 12:17 AM
psychoazn's Avatar
I've had no problem having the AIM Solo DL capture data.
On the 06+, I know that the ECU needs to be set to CANBUS; I have a 08.
Keep us posted!
Old Nov 8, 2012 | 05:36 AM
sheel's Avatar
Keep us posted!
Ok thanks... for the 06, did you have to tap into the ECU wiring for CAN? For the 02, we should be able to hook directly into the OBDii port so it comes with a different cable.
Old Nov 8, 2012 | 08:18 AM
psychoazn's Avatar
I'm plugged directly into the OBD2 port.
bbp
Aug 19, 2013 04:38 PM
Randman
Aug 19, 2004 11:56 AM
S2KANDRE
Jun 22, 2004 02:29 PM
bills2k_2001
Jun 3, 2004 11:51 AM
Redline9K
Sep 20, 2001 10:59 PM
