alignement problem
Old Jun 3, 2012 | 03:39 PM
  #21
robrob's Avatar
after a long drive on each the steering wheel goes off center.
The op said "goes off center" so it wasn't that way from the shop so the adjusters slipped. I use a large 1/2 socket wrench and torque the adjuster lock bolts as hard as I can and that keeps them from slipping.
Old Jun 3, 2012 | 11:12 PM
  #22
davidc1's Avatar
K, I'll tell that to the guys who do the alignment next time...or, I'll just do it myself after I get the car home.
Old Jun 27, 2012 | 08:41 PM
  #23
sideways2k03's Avatar
Hey I got a question for you guys,I set my negative camber to max but the problem is that it gave me alot of toe out. I was trying to figure out in order for me too fix my toe and keep my negative camber do i need adjustable toe links?? or can i come to a solution without it?
Old Jun 28, 2012 | 04:04 AM
  #24
murderedrsx's Avatar
Toe will change when you set camber. If i remember correctly set the camber first then toe. You might lose a .1-.2 degrees of camber when resetting toe.
Old Jun 28, 2012 | 10:16 AM
  #25
So basically there is no real way around losing camber when messing with toe unless you get adjustable toe??
Old Jun 28, 2012 | 12:41 PM
  #26
robrob's Avatar
In the front you really don't lose any negative camber when you set the toe but in the rear with both adjusters at full extension (max neg camber) you will lose a significant amount of camber as you set the toe. Since rear camber is normally limited by the toe adjusters, replacing them with extensible toe links (like a bump steer kit) will add a little more maximum negative camber.
Old Jun 30, 2012 | 03:15 PM
  #27
ahhh okay i got you, thanks man been trying to figure that for a minute haha..
Shark
Jul 27, 2010 08:34 AM
pikkashoe
May 11, 2006 08:59 AM
Formula
Sep 3, 2005 03:33 PM
aklucsarits
Sep 2, 2004 07:24 AM
jjanicke
Jul 23, 2002 03:55 PM
