Alignement with stock wheels or new wheels
Old Apr 25, 2016 | 05:08 PM
S2kmybabe's Avatar
Default Alignement with stock wheels or new wheels
So the shop that was supposed to do my alignment today called and asked for my stock wheels because he said my car was too low for his tool... he said it doesn't matter if he does the alignment with my stock wheels or my current wheels, I don't really like the idea but I don't have the choice since I need this done for Friday so what do you guys think?
btw my setup is RPF1 17x8+45|225/45F and 17x9+45|255/40R on RS3
and I asked for -2.7 camber front, 6 caster, and 3,2 camber rear,1/4 total toe in
(the car isn't seeing any street road)
Old Apr 25, 2016 | 07:31 PM
freetors's Avatar
IF you are specifying INCHES of toe, then yes, the wheel size does matter due to math and trigonometry and stuff. Degrees are degrees and will always be the same with whatever wheel size you run.
Old Apr 26, 2016 | 01:41 AM
S2kmybabe's Avatar
So if we take in consideration that the stock tire is 1,181 inch smaller, can we determine how much toe it's going to be on my new wheels if he does alignment with the stock wheels?
Should I ask for more toe or less toe to compensate for the smaller wheels?
Damn, this sucks.
Old Apr 26, 2016 | 08:20 AM
rip_ej1's Avatar
OP, just convert inches to degrees.
Convert toe inches to degrees
Old Apr 26, 2016 | 08:25 AM
summitrider2012's Avatar
i would use the tires your going to race on. if he cant do it i would maybe look at another shop. i use ramps to get mine on at my work
Old Apr 26, 2016 | 06:38 PM
Pimpo's Avatar
Isn't the alignment done at the hub of the wheel with those machines? I think the shop is correct and it doesn't matter...
XxMerlinxX
Apr 19, 2013 04:56 PM
HondaS
Jul 16, 2007 01:21 PM
specialk22tt
Nov 11, 2006 06:15 PM
Nhan
May 11, 2005 01:18 PM
WebGod
Dec 14, 2001 11:14 AM
