Alignment advice
The s2000 generally requires more front camber than rear if you are talking about getting even tire temps and tire wear. I would not really call it a preference. Every setup will be different though, there is no one optimal camber setting for all cars, it is setup specific. You can tune the balance by moving away from the optimal camber on one end but if you want to be as fast as possible, you are better off using optimum camber (dictated by temps) and tuning balance with roll rates IMO.
I think your decisions and path forward are good.
^I agree. ~7deg caster is good. If your not doing any auto-x/ HPDE than just do -2 camber as long as your wheels still clear. No reason to run so much for "spirited driving" IMO.
Andew, what was your experience with the x brace? I've always felt the s2k was very rigid and thought there wasn't any tangible benefit to the bracing. But I've never driven with one. Is it worth getting one?
I don't have an x brace on my car currently, but have been extremely happy with the steering feel improvement of the ASM cross bar. Moving to stiffer spring rates it becomes much more clear how the chassis and subframe flex effects the car under load. I will definitely be trying out the Spoon x brace on my car. I am more concerned with driving feel than I am lap time. I want a car that is fun to drive fast and is fast in all scenarios, not a car that is fast in a few scenarios and feels like crap. Moving to stiffer suspension and more negative camber provided so many benefits, but steering feel was definitely sacrificed a bit. It is very easy to forget how the car felt once you have adjusted to new mods, but having driven the stock car hard for a long time that was the first thing I noticed after installing the suspension, but with the ASM bar I would say the steering feel is better than it was stock with only -0.5 front camber. At normal speeds the stock steering feel was great, but once you started pushing and the tire starts to roll over, you lose that. With more camber the car feels a bit more numb at normal speeds, but great loaded up, with more camber and the ASM bar I get the great normal speed feel and even crisper feel with the car loaded up.
The S2000 already sets a high standard in terms of driving feel, so the range of improvement is smaller, but it is definitely still possible, and worth it in my opinion. If your main concern is laptime/$ then maybe not, but in that scenario seat time is more valuable than pretty much everything but tires.
Yeah I def won't be competing professionally or anything like that at this point, but just want to get the most out of what I have and learn a thing or two about driving/handling by doing some AutoX.
I think the best thing would be to run -2.5 camber all around, 6.5 caster up front, 0 toe front and 1/16th total toe rear (~0.15 degrees?). I'll start to adjust the specs accordingly as I develop driving preference. I wasn't too sure what to look for in terms of camber bias (since I'm not running a completely square setup) and since this will pretty much be my first time getting an alignment focusing more on performance, so thanks for giving me a starting point guys.
What do you guys think of my suspension mods by the way? (besides the X brace
)And the x brace is
With those spring rates, front tires size/compound, and ride height you'll be putting significantly more load back through the chassis. This is where the bracing comes in. More load back through the chassis, whether it's cornering or bumps, want to bend the body. When you stiffen up the body it allows the dampers/springs and bushings to do their job since the body isn't absorbing the energy and changing the force going through the damping. Since all of that flexing takes time (milliseconds) it slows the response of the moving parts (control arms, dampers, and springs) causing delays in how the chassis reacts to steering inputs. On the S2000, the main place to improve steering feel is in the front subframe and at the gearbox. The x-brace is a great way to stiffen the front subframe and improve it's rigidity.
Think of it as pushing on a flimsy wall. When you push on a flimsy wall, the wall flexes and deforms. When you push on a block or concrete wall - you move. This is analogous to the steering rack trying to move the knuckle/wheel/tire. The chassis is the wall being pushed and you're essentially the tire, so when the tire pushes back on a flexible chassis, the chassis deforms a little and the tire doesn't move. When the tire pushes back on a rigid chassis - the tire moves. You go where the tire points you.
I'm leaning towards -2.6 F -2.4 R, keeping a -0.2 bias as Andrew suggested.
Good plan.
And the x brace is
in my opinion as well as I have noted. After you have gotten use to how the car feels with your new setup and alignment, go for a nicely spirited drive on a specific route, take the x brace off, and go do the same again. If you are ever doubting a mod and it is relatively easy to remove, get use to driving the car with it, and then remove it to test again without it. Time consuming but the differences are more apparent that way, and always try to go into testing something without predicting what will be different.
And the x brace is
Originally Posted by ndogg' timestamp='1396660602' post='23098120
X brace does nothing FYI.
I post this to try to save future s2k drivers from wasting their mod money.
