alignment difficulties
Old May 25, 2004 | 03:28 PM
davepk's Avatar
Here is a thought that just ocurred to me...
I've dropped my tranny a number of times and part of that procedure involves lowering the engine subframe. The lower front a-arms are attached to this frame. One of the things i've noticed is that the frame has some wiggle room as its raised and tightened up against the rest of the car. With the upper a-arms attached to the body any misalignment of the subframe from its previous position would amount to a change in the alignment. Move it far enough to one side and you can increase the camber acheivable on the side and reduce the camber achievable on the other.
Anyway, just a thought. Had any tranny work done lately?
Old May 25, 2004 | 04:40 PM
jguerdat's Avatar
[QUOTE]Originally posted by toma
The front adjustment on the driverside front of the lower control arm, the bolt with cam plate, showed the cam plate maxed.
hypforlife32
Sep 23, 2011 02:50 PM
slatkimalict
May 20, 2010 07:49 AM
gaus
Jul 8, 2009 05:19 AM
bps2000
Jun 15, 2007 09:19 PM
hylysly
May 25, 2006 09:10 AM
