Alignment Help
Old Apr 18, 2004 | 06:41 PM
dkmillerii's Avatar
Default Alignment Help
I'm trying to find out what the:
1. Factory alignment specs are
2. What the suggested alignment specs are for autocross
3. Local (near Catonsville, MD), trusted mechanic to go to for alignment
Thanks,
Don
G. Obadia (333, I think) sent me some of this info, but I lost it. Please help me out!
Old Apr 19, 2004 | 02:30 AM
jguerdat's Avatar
Need - more - data...
What other mods (front swaybar)? What size tires?
Stock specs for your '02 are -0.5 deg front/-1.5 deg rear camber. You generally want about one more degree negative camber for all-out performance on R-compound tires with a big front swaybar, 0 toe in front (maybe 1/8" total toe OUT) and 1/8"-1/4" toe IN for the rear. Too many variables to be more accurate at this point...
Old Apr 19, 2004 | 08:06 AM
dkmillerii's Avatar
On the street, I run stock wheels with Toyo Proxes T1-S.
For autocross, I have stock wheels with Kumho Victoracers.
I have a Generation 1 Saner sway bar set to the inner most hole.
Other than that, everything else is stock.
Old Apr 19, 2004 | 10:23 AM
333's Avatar
333
allen automotive is down by radial tire in silver spring. the guy there does my car and seems to know what he is doing. drop my name if you go.
Old Apr 19, 2004 | 11:09 AM
jguerdat's Avatar
I'm not familiar with the Saner bar. Is that the stiffest setting or the least stiff?
Generally, however, you can use the specs I quoted above as a starting point. Note that it will wear the inside of your street tires with that much camber. I use the UK specs which end up with -1.0 deg. front and .2.0 deg. rear. Still get inside tire wear but it's acceptable (to me). Note that the exact settings are also a function of how YOU like the car - do you want a little understeer or do you like the rear end more active? As a newbie, a little understeer is "safer" as long as you understand that you can make ANY car understeer with the wrong inputs (e.g. entering a turn to fast and cranking the wheel over)...
Old Apr 19, 2004 | 11:59 PM
dkmillerii's Avatar
That is the stiffest setting.
Old Apr 20, 2004 | 02:22 AM
jguerdat's Avatar
Ok, so you have as much understeer (or least oversteer) dialed in via the bar. You can use tire pressures and/or camber to get the car to take advantage of that stiffness. It's still a personal call since you need to dial the car in to run as you like it. You're in the ballpark - now you need to figger out how to hit a homer...
Old Apr 21, 2004 | 09:53 PM
pfb's Avatar
pfb
Good alignment info here:
http://forums.s2ki.com/forums/showthread.p...light=alignment
Old Apr 27, 2004 | 08:20 PM
wannabuy's Avatar
Keep info coming please. I must take advantage of the question.
mball19
Apr 27, 2015 08:00 AM
a2l90e
Jun 5, 2014 04:46 PM
pistolpete17
Mar 11, 2009 08:56 AM
David NJ
Jun 12, 2001 03:54 AM
cdelena
Nov 14, 2000 06:41 AM
