Alignment settings to help control oversteer.
Old Jun 18, 2004 | 01:25 PM
LAE's Avatar
LAE
My 2 cents.
Alignment:
Your alignment is close. I run
Front: -1.6 camber, 5.4 caster, 1/16" toe OUT
Rear: -2.1 camber, 1/4" toe IN
Gendron bar, hollow: full stiff on concrete, one off full soft on asphalt (still playing)
A3S04s 46 psi front, 45 rear. Temperatures across the tyres are good at these pressures.
If you have a 1/4" toe out I understand oversteer will be a BIG problem.
Old Jun 21, 2004 | 05:00 AM
KeithD's Avatar
Little update... Set my cold pressures on the Hoosiers to 40 front / 35 rear and the car felt good. I ended up 3rd in my class (got nipped for 2nd by a Boxter S on his last run by 0.3). Ended up with the 4th or 5th fastest time of the day out of a 100 or so cars.
Old Jun 21, 2004 | 09:16 AM
jguerdat's Avatar
[QUOTE]Originally posted by KeithD
Old Jun 21, 2004 | 09:49 AM
KeithD's Avatar
Well an S2000 took FTD-Prepared in ASP, and an S2000 took FTD-Stock in BS.
A good day for the S at autox yesterday.
S2000_916
Aug 7, 2013 11:15 PM
anarchy187
Dec 2, 2011 02:31 AM
SPLNDID
Mar 14, 2010 02:19 PM
alexdog1
Feb 17, 2009 06:56 PM
E-Z
Jun 2, 2007 12:57 PM
