Analyze my setup...
Let's talk about your shocks. Let me assume you have double-adjustables.
If that's the case then:
You seem to have oversteer on exit. Meaning, if you are doing things correctly, you are unwinding the wheel while rolling your foot on the gas, correct?
During this phase of the turn, weight is being transfered from the outside front tire to the inside rear tire. That means, your outside front shock is working on rebound while your inside rear shock is working on compression.
So if you want less oversteer on exit (or more understeer), you need to:
STIFFEN the compression in the REAR and
SOFTEN the rebound in the FRONT.
Sounds contradictory, doesn't it? The reason for this is that during exit, as I said before, you are taking weight away from the outside front tire and transfering to the inside rear tire. So the faster you unload the front tire and load the rear tire, the more rear grip you'll have.
Then, in your case, if you want more rear end grip, you should speed up unloading the front by softening the rebound. Or speed up loading the rear by increasing compression. Or both. Does it make sense?
The "soften the rear, stiffen the front" theory for fixing oversteer works only on flat out constant radius turns, when the weight is been transfer to both outside tires.
The beauty of double adjustables is the capability to adjust the shocks for each phase of the turn.
Originally Posted by S2Kretard,Apr 8 2008, 11:47 AM
Wrong, try again.
Originally Posted by Suspension,Apr 6 2008, 03:18 PM
Escalvante, I just got under my car in preparation for the April 12th track day at Buttonwillow with SpeedVentures and noticed something interesting. I have SRCs as well and I remember you posted on the forum asking for length settings for the dampers and I posted what the manual said. Perhaps you have the same problem as me. My rear is unsettled over bumpy roads, as well.
I had my rear wheels up on a ramp to inspect all the suspension components and I noticed that I had about a 1/4" of damper travel in the rear, as it sat, until it would start in to the bump stops. I have been riding on bumpstops for the past 6 months! I thought the setting TEIN gave would be reasonable, but it appears I need to add a lot of preload to the spring so I can get some bounce travel back. I hope to have time this week to make this adjustment before getting to the track (I have not tracked with the SRCs yet, but have done ~8 autocrosses).
You should put your car up on ramps and check how much travel you have in the rear. My fronts had about 1.5" of travel until the bumpstop which seems more reasonable. Riding on the bumpstops would make the car very twitchy at corner exit over even the slightest bumps.
I'll report back if I had time to make this adjustment. Let me know if you have a similar limited travel in the rear.
eurotrashdtm: I never tracked the car in stock form. However, I used to be on KW V3s and now the car feels a lot more nimble as the car seems to be "taking a set" quicker.
Smirf: The driver mod takes time and I'm definitely on my way... BUT, I can't become a good driver without a car that is properly setup.
S2kRetard: I have gotten the car's alignment adjusted today with 0 degrees toe-in in front and 1/16 toe-in in the rear. Everything else stayed the same. Although I would love to replace the stock rear sway, I won't have time before Friday's event. I'll do it before the next event for sure.
Why do you think Naka is wrong? I'm interested in what you would suggest. Thanks.
Will you be at Buttonwillow on Friday?
I say Naka is wrong because.... For a relatively soft, heavy, low-hp street car, under acceleration the rear dampers have only one main issue: helping to optimize the contact between tire and asphalt. Your S2K doesn't have enough power & grip to generate a fast/big enough rearward load transfer to be concerned about the instantaneous load transfered onto the rears through the dampers due to big forward vehicle acceleration. Their main goal is to be as compliant as possible while still providing enough body heave control under acceleration. If the rear is already skaty under acceleration, part of it could be that the rear bump is too stiff, not allowing the rear to be compliant enough over bumps & irregularites. Increasing the rear bump stiffness is probably a step in the wrong direction.
But, the real answer is to get comfortable on track again with your normal damper settings, and then try a few clicks in one direction and a few clicks in the other direction back-to-back. Then it should be pretty obvious
Also, it could be caused by a million other things, so.... I doubt the answer lies in one simple fix. It's probably a combination of things, with dampers *maybe* playing a small part.
It doesn't look like I'll be at BW... Even if I do go, it'd be for one day only, and probably not Friday...
Now this may complicate things more but Suspension and I were talking about it and it seems that my car has about 3/4" travel for the shocks before they hit the bump stops.
I also spoke to tein today and what needs to be done is to compress the helper springs a bit more by tightening the spring perches to give you more stroke before hitting the bump stops then readjust your ride height the the bottom nut.
So I would check to see how much room you have before you hit the bump stops.
What I'm saying is, yes, you do have enough rearward load transfer to be concerned about it (although not necesarilly "instantaneous") during acceleration. The closer you are to the ragged edge, the more significant these subtle changes in weight transfer are.
Originally Posted by Naka,Apr 8 2008, 08:42 PM
I beg to differ. I believe you are understimating the capabilities of a shock/spring combination custom built for high performance applications. Big differences in car handling/behaviour can be achieved by shock tunning alone. Although "low-powered" and "heavy", the weight transfer on the ragged edge is significant enough that you could easily spin in you lifted in the middle of high speed turn (even with stock shocks).
Agree on this. If the rear feels "skittish", then it probably is a case of too much compression, as you just stated. But if it is just an unstable back end under acceleration due to poor rear end grip, then the advise stands as originaly stated.
My bad, carry on...
Originally Posted by S2Kretard,Apr 9 2008, 05:50 PM
And this "ragged edge" you speak of... sounds scary.
