Analyze my setup...
we do suspension for a living and seems you have classic case of too much toe in front resulting in a contribution to your looseness later and combined with too much rebound (at least on the rear dampers).
as to camber, setting at a shop is only a guess even with data from a previous outing. the only way to determine accurate camber setting is with a probe pyrometre - good cheap ones run about 100-150 depending on whether you get a protective case which is recommended. cold temps mean nothing - it is the hot temps that matter. each r cpd tyre manufacturer is different for optimum but nearly all fall in the 35-40 range - big range but that's what it is. street tyres should be running hot what the manufacturer suggests typically around 36. if you want email me and we can discuss - pming is too much a hassel use the email option please.
Originally Posted by mikegarrison,Apr 15 2008, 07:02 PM
Which one you use is not as important as it is to use the same one all the time.
However, they don't last forever, so it's a good idea to have a few and double check them against each other every so often, just to make sure none of them have gotten too messed up.
Or you could get a really good one and carefully calibrate it often, but that's way too expensive unless you are talking about a pro team.
Originally Posted by ESCALVANTE,Apr 8 2008, 06:37 PM
..Although I would love to replace the stock rear sway, I won't have time before Friday's event. I'll do it before the next event for sure...
Assumptions:
Resolutions:
current changed) stiffer front and disconnected rearbar. *This could be overkill though as the relative difference may be too great.Good luck and I did recommend this to s2k driver in Dubai racing last month and he said it helped out at least 2 seconds. He went from stock front, stock rear to stock front and disconnected rear and improved his times several seconds. He also said it was much more controllable. It was an exhibition for the GP2 event so he was happy to pick up some time for it
