Any FRP GP Wings?
Old Jul 11, 2009 | 08:28 AM
JackOlsen's Avatar
[QUOTE=EternalShadowAW,Jul 10 2009, 11:56 PM] twin tiered or multiple element slat style wings are actually quite good at making a lot of lift especially at extreme angles of attack near stall.
Old Jul 11, 2009 | 09:36 AM
krazik's Avatar
Administrator
Originally Posted by JackOlsen,Jul 11 2009, 08:28 AM
Chances of a multi-element wing producing benefits over a single-element wing in a production car envorionment: basically zero.
y is that? </curious>
Old Jul 12, 2009 | 08:30 PM
JackOlsen's Avatar
Because production cars aren't designed with managing airflow in mind. Dual-element wings require not only very precise positioning of the two elements relative to one another, but also very predictable and non-turbulent airflow (both in a straight line and turning) for the sped-up air from the first element to feed the second in a beneficial way.
That isn't to say there won't be some benefit from an off-the-shelf dual element one-size-fits-all wing -- but it won't provide a meaningful improvement relative to a single-element wing, especially if you consider a single-element wing with a cord length comparable to the two (dual-element) pieces combined.
A 1"x10" piece of pine lumber on a couple of uprights will provide some aero improvement. So does sticking your hand out the window. But the fine-tuned ground-sucking stuff we see on aero-engineered cars requires head-to-toe airflow management -- which is almost impossible if you're sticking with the shape of a production car.
/pretend-expertise
Old Jul 12, 2009 | 11:42 PM
EvasiveMotorsports's Avatar
Former Sponsor
we are getting a shipment of Voltex wings in soon, the Type 2 wing is actually more affordable than you think. FRP can be special ordered and is a lot cheaper than CF.
Old Jul 13, 2009 | 02:51 PM
urBan_dK's Avatar
Why would anyone want to create lift with a wing on a car
Old Jul 13, 2009 | 04:13 PM
TheNick's Avatar
the sarcasm escapes joo
Old Jul 13, 2009 | 04:35 PM
mikegarrison's Avatar
What "dual element" wings do is transfer energy into the boundary layer of the suction side of the following element. This is intended to reduce flow separation, but it comes with some costs.
So if you are running into problems with your airflow separating, this is one way to solve them. If you are not having those problems, there is cost in terms of lost efficiency but no benefit.
Old Jul 13, 2009 | 04:45 PM
Antonov's Avatar
Originally Posted by INTJ,Jul 9 2009, 04:10 PM
The multi-angle style that they tested had far worse performance in varying locations and heights compared to a single angle wing.
I read that article, and I think its a gross generalization to say that. There are a number of conclusions they came up with, none of which are ground braking. There are advantages to running 3D elements, but ultimately their efficiency is a function of placement.
Old Jul 14, 2009 | 11:28 AM
INTJ's Avatar
"(T)he style that they tested..." Not a gross generalization, a specific summary of the conclusions. None of them are ground breaking, just a reminder that dropping 2x$ on a "special" wing may in fact yield worse performance than a straight design.
As with EVERY and ANY analysis of data, it is all dependent on the type of model, the initial conditions, the parameters used, etc., etc. None of these will hold constant in the real world and vectors will come in at all angles.
Old Jul 15, 2009 | 10:41 AM
Antonov's Avatar
Exactly.
S2Ker206
May 7, 2018 04:18 PM
AWWHITE s2k
Oct 2, 2012 02:03 PM
Domofun
Aug 31, 2012 11:12 PM
BowaBowa
Apr 19, 2009 11:59 AM
LowBudgetS2K
May 31, 2005 02:16 PM
