AP1 front hub pivot angle question
Kingpin angle is the angle of the line drawn through the upper and lower ball joint, compared to vertical if you were looking at the suspension from the front. That doesn't sound like what you're looking for, but as I said I'm having trouble following without a picture.
He is talking about Kingpin angle. There are lots of various terms for this angle. Caster is the angle of these two ball joints when viewed from the side of the car, kingpin angle is the angle of these two ball joints when viewed from the front of the car. FYI: Scrub radius is the difference between this line extended to the ground and the center of the tire contact patch. As scrub radius increases, the amound of load put into the steering wheel increases while braking on uneven or mis-matched surfaces.
It's not adjustable, other than it changing as you change camber due to the lower balljoint moving in and out. They don't match perfectly side-to-side even on new cars. If it's out and both wheels are set to the same camber number, the hub/knuckle is likely bent.
After rereading his description I think you're right, it is kingpin angle.
I have no idea how you'd measure this though to that much precision, since this isn't a formula car, so my question still stands - how was it measured? If you can describe that then maybe someone can measure it and see what it is. I bet it will be tough since it has to be at ride height.
Also wouldn't our ride height have to match yours, or we'd get different numbers? Maybe it won't change that much, I'm not sure.
thanks for the input guys
does any body now what the kingpin angle is for a stock AP1 is ?
just wandering which side is not OK (maybe damaged ?)
if I have 8° on one side and 12° on the other...
</div>
</div>
I think you're talking about steering axis inclination(SAI). you can also set both adjustments to caster and camber to a max position to get a better measurement of SAI. Because it's always different if either side has a height(coilovers), weight, camber, and caster difference. You cannot adjust for SAI on an alignment rack, it just changes with the alignment
and if i remember correctly, to calculate SAI use this:
.75/tan(X-Y)
x=from ball joint to wheel center(hub face)
y=from ball joint to wheel base(actual wheel, not including tire)
if x or y is different on either side, it will tell you more if something is bent if camber and caster is maxed. but you're still shooting blind since no one has a perfect off the lot s2k that you can measure to get a known good measurement
.75/tan(X-Y)
the car's suspension has now been fully rebuilt with Spoon bushing and the nitron shocks overhauled
settings as below + corner weighting
front Caster Left 5°20 «
Caster Right 5°15 « (max possible)
Camber Left -1°20 «
Camber Right -1°20 « (max possible)
Toe Left 0°00 «
Toe Right 0°00 «
Total Toe 0°00 «
rear Camber Left - 2°30 «
Camber Right - 2°30 «
Toe Left + 0°20 «
Toe Right + 0°10 «
Total Toe + 0°10 «
and so with these settings there's 11°26' kingpin angle on the left and 7°41' on the right.. the question being : which side has a problem ?
Camber Left -1°20 «
Toe Left 0°00 «
Toe Right 0°00 «
Total Toe 0°00 «
Toe Left + 0°20 «
Toe Right + 0°10 «
Total Toe + 0°10 «
