AP1 front hub pivot angle question
Old Jul 2, 2012 | 01:59 PM
  #21
IntegraR0064's Avatar
Originally Posted by euroS2K
the car's suspension has now been fully rebuilt with Spoon bushing and the nitron shocks overhauled
settings as below + corner weighting
front Caster Left 5°20 «
Caster Right 5°15 « (max possible)
Camber Left -1°20 «
Camber Right -1°20 « (max possible)
Toe Left 0°00 «
Toe Right 0°00 «
Total Toe 0°00 «
rear Camber Left - 2°30 «
Camber Right - 2°30 «
Toe Left + 0°20 «
Toe Right + 0°10 «
Total Toe + 0°10 «
and so with these settings there's 11°26' kingpin angle on the left and 7°41' on the right.. the question being : which side has a problem ?
What's your ride height? Those numbers on the right seem low for max adjustment. So I'd guess right side has the problem. Do you have any offset ball joints or anything like that to affect your alignment? Maybe if everything's stock and your ride height is high then maybe it's normal but it still looks low to me.
Old Jul 2, 2012 | 08:58 PM
  #22
robrob's Avatar
Your rear toe numbers look wrong. Toe Left 20 + Toe Right 10 should = total 30, not 10. If it does = 10 then that implies that one wheel has toe in and the other toe out.
You might be able to get higher negative camber in the front by lowering the caster.
Old Jul 3, 2012 | 12:13 PM
  #23
euroS2K's Avatar
integraR0064: suspension is stock other than Nitron oneway adjustable shocks & Eibach springs
and ride height in millimeters (...) is FL 101, FR 105, RL 102, RR 108
(car is relatively low, in fact a little too low (at the rear) for the Toyo R888 225/50*16 on Spoon wheels that I think are going to scrub on the wheel arches at track loads ...)
robrob: of course your right, typo.. numbers in wrong order, rear toe is 0°10' either side and total of 0°20'
Old Jul 8, 2012 | 10:23 AM
  #24
euroS2K's Avatar
anyway I guess integraR0064 is right:
if caster & camber are limited to these numbers on the right hand side, that's pobably where the problem is ...
teamking
Feb 29, 2016 01:14 PM
pennywisdem1
Dec 21, 2012 06:02 PM
turbo8765
Aug 13, 2010 02:47 PM
dsddcd
Mar 28, 2008 09:35 AM
tilt
Oct 18, 2006 12:48 PM
