AP1 x 4 Rears
Old Aug 17, 2012 | 02:27 PM
iDomN8U's Avatar
Default AP1 x 4 Rears
I'm looking to run 245-45-16 Ap1 rear square setup for use on my garage queen / 4 times a year track days.
My street tyre choices are RE-11 ...
My R compound options are abundent (R888, RA1, etc)
I want to avoid tapping the hubs so I was thinking about going with a spacers - Front:15mm Rear:25mm
Question: Will the spacers allow me to avoid the hub diametre issue?
Anyone else have any suggestions or running a similar setup?
Lowered on Kwv3
Thank you for your thoughts
P.S: Yes I anticipate running a softer rear sway bar or perhaps a stiffer front. But i'm interested to see how this handles with just coilover adjustments.
Old Aug 17, 2012 | 03:26 PM
Trackforged's Avatar
Former Sponsor
On my daily AP1 I run 225/50/16 street tires, on ap1 rears square setup, I just bored out 2 of them to fit on the front. It's an option
Evan
Old Aug 17, 2012 | 07:54 PM
daverx7's Avatar
Lowered on Kwv3
I run 5mm spacers up front to allow me to use the AP2 rears up front without boring out the wheels, but I didn't feel comfortable enough using the factory studs and got longer ones.
Old Aug 17, 2012 | 08:03 PM
josh7owens's Avatar
I have 3 sets of AP1 wheels. 2 normal sets and one set thats all rears bored out. Good DD wheels.
Old Aug 18, 2012 | 08:20 AM
iDomN8U's Avatar
Evan
Do you have a picture showing the fitment on the front?
I like the idea of running spaces for a couple reasons vs. boring.
A) I can get a flushed look
B) Dont have to pay someone to bore out the two rims. I can take the money to help offset the cost of the spacers.
C) I can always sell the spacers if I decide on a different route
D) If I damaged a bored out rim, I can replace with another oem with having to get that one re-bored. *ninja edit*
E) I can run a spare tire in case of flats
Old Aug 18, 2012 | 08:24 AM
iDomN8U's Avatar
Evan
Any track time with 225? what did you think? sway bars?
Old Aug 18, 2012 | 08:26 AM
iDomN8U's Avatar
Lowered on Kwv3
I understand 5mm is about the limit on stock studs, how many turns were you able to get with the stock studs?
Old Aug 18, 2012 | 08:41 AM
Carbon Blue's Avatar
Evan
typically with non stag setups, the square tire size will only increase oversteer, non stag guys typically go with only a big front sway with a stock or no rear sway to dial out the oversteer. I would think 225x4 would be oversteer city with an aftermarket rear sway. General rule of thumb (and i mean GENERAL) is that if your on a staggered setup then a rear sway is fine and is totally dependent on the driver. I run the stock ap1 sizes 205/225 with eibach bars, front on stiff, rear on soft with bilstein pss coilovers. I went to a track a month or so ago and the car pretty much handled like stock with the exception that everything was a tad bit stiffer with faster weight transition. I didnt notice any more increased oversteer over stock.
Old Aug 18, 2012 | 09:07 AM
murderedrsx's Avatar
Im running 3mm spacers on my fronts and it gets right at 5-6 turns. Anything less than that and you should go for extended studs. Extended studs are kinda a pia unless you already plan on doing wheel bearings. The other type of bolt on spacers i would feel comfortable on at the track. They tend to loosen easily and ive seen catastrophic failures with them.
Old Aug 18, 2012 | 09:26 AM
daverx7's Avatar
It has been several years, but I think I got 4-5 turns. However, when I took it out for a quick run on a curvy road and got it back home, I had to retorque it pretty good. This happened at least twice, so I punted and got the longer studs. YMMV
-Dave
