AP2 Brake Ducts
Originally Posted by duffsr' timestamp='1357933358' post='22260966
Little bit different technique, but has anyone else seen the Motoiq Project S2000 brake ducts? They're an easily removable single piece control arm mounted style.
http://www.motoiq.com/magazine_artic...-upgrades.aspx
Seem very simple and effective.
If someone wants to manufacture a brake duct kit, that is the way to go for sure.
Those MotoIQ ducts are pretty cool. I'm thinking you could make something similar using standard silicone brake duct hose and inserting an L-shaped piece of aluminum or plastic into the hose to "oval it" and give it the required bend. You could then Zip-tie it to the lower a-arm.
Hey Rob your Idea with using the ducting is a good one.
Rivet or bolt the cylinder style piece (that's been used in lots of duct kits) to the backing plate, connect the 2.5" flex hose to it, zip tie the silicone ducting flex hose to the lower a arm and put a rectangular funnel type end on the other side of the flex line to catch the air.
All we need is Rob to do it and throw up a DYI on his web site.
Are you interested Rob?
Something I don't think was specifically mentioned with the MotoIQ project car, the dust shields were completely removed. That alone has to make a huge difference in managing the temperature of the inner rotor face I think. Do the front dust shield serve any other purpose other than helping the wheels stay clean? It seems like they would also act as a heat shield for the ball joints, brake lines, etc.? It seems many will wrap the ball joints and brake lines with heat tape to keep them from from getting thermal damage. Could be wrong about this, but seems like a good idea whether or not you have removed your dust shields.
At least that's the reason I'm going to fab up rear ducts for my car - increased bearing/hub life.
