I did a search but it was not very helpful. What SOLO II class would a S2000 with intake/exhaust/X-brace/STB and OEM wheels/tires/shocks with Ground Control lowering springs be in? Thanks.
"Strut bars are permitted with all types of suspension. Strut bars may be mounted only transversely across the car from upper right to upper left suspension mounting point and from lower right to lower left suspension mounting point. No other configuration is permitted. Additional holes may be drilled for mounting bolts. Only bolt-on attachment is permitted. "
I believe the X-Brace is legal for ASP as it attaches the lower left suspension mounting point to the lower right suspension mounting point. The rules say nothing about number of attachment points.
[QUOTE]Originally posted by GEARHEAD
[B]"Strut bars are permitted with all types of suspension. Strut bars may be mounted only transversely across the car from upper right to upper left suspension mounting point and from lower right to lower left suspension mounting point. No other configuration is permitted. Additional holes may be drilled for mounting bolts. Only bolt-on attachment is permitted. "
