Autox setup vs track day
Yes! Watch how much toe you run on the track. If you use a lot of toe for auto-x and then go to track you will toast your tires. I run max - camber and 0 toe most of the year. That way I can switch between Auto-x and track with no worries. If going to a national auto-x event you will need to add + & - toe adjustments to your alignment to be competitive.
is more toe significantly harsher on tire life than more camber?
im running 0.33 inch toe and -2.5 degree camber now... and was planning to reduce the toe but increase camber to -3.0 degrees?
will this increase oversteer?
integfoo
Jun 6, 2015 06:15 PM
s-duces
Apr 11, 2003 11:03 PM
