MY04 autox alignment
OK. I know there's a search button! I've looked but haven't really found MY04 camber/toe/caster settings for optimal autox alignments. Track alignments can vary depending on the venue. I do not drive my car alot on the street so I can live with a radical alignment. I haven't lowered it either so can someone please enlighten me.
Thanks
Thanks
'04 settings seem to be very similar to pre-'04. The typical seems to be about -1.5 deg. f/-2.0 deg. r camber, 0 toe front, 1/4" toe-IN rear and as much caster as you can get with the front camber. Modify from there...
What kind of tire/surface do you run on?
For Kumhos, -1.7/-2.0, 0 toe front, 1/8" total toe in rear worked well. For the new Hoosier A3S04s, more camber is better, and I might try some toe out for the front.
Peter
Peter
