looking for advice on track alignment setups.
Old Jun 5, 2015 | 02:56 AM
integfoo's Avatar
Default looking for advice on track alignment setups.
so i know it all depends on what track it is, driving technique, and skill set but would just like to get a general idea on what settings i should start at for road racing. I've done two lapping days so far at the ridge in wa. with just the oem specs. I've recently just installed new suspension (hipermax 4 sp's) and front solid 30mm sway bar. before i head to my next track day, I'm going to get an alignment and corner balance. like to get some ideas from some experienced individuals who have tried many setups.
i am running a non staggered setup with 255/40's. after doing some research, i have some ideas on what settings i should start with;
front:
camber -2.5
caster 6.3 deg
toe 0
rear:
camber -2
toe 0.125" total toe in
what do you guys think? any input would be greatly appreciated and looking forward to learning from you guys!
Old Jun 5, 2015 | 06:29 AM
devildust's Avatar
You wont get that much front camber without camber joints.
Old Jun 5, 2015 | 02:26 PM
integfoo's Avatar
i can get -2.5 max front and -3 rear with stock parts. it all depends on how low the car is.
Old Jun 5, 2015 | 07:30 PM
GEARHEAD's Avatar
Your numbers look like a great starting point. I prefer a touch of toe out in front and zero toe in rear but I like a fairly loose setup.
What tires and spring rates are you running? - That impacts optimal alignment as well.
The Ridge is a great track. Good luck.
Old Jun 5, 2015 | 10:10 PM
gptoyz's Avatar
what generation are you? ap1 or ap2?
if ap1, do you have a rear anti bumpsteer kit?
If you have an ap2 or an ap1 with a bump steer kit; I would say that definitely too much rear toe. I run 1/16 total toe in and I might consider reducing it to 1/32 total toe in
Old Jun 5, 2015 | 10:18 PM
integfoo's Avatar
hmm interesting. i have 16k springs and falken rt615k's for tires.
Old Jun 5, 2015 | 10:21 PM
integfoo's Avatar
i have an ap2. why do you say its too much rear toe in? what do you not like about it? i heard its bad for tire wear but rear end is tighter?
Old Jun 6, 2015 | 02:31 AM
gptoyz's Avatar
toe-in in the rear keeps the rear end settled but it also kills drive
Old Jun 6, 2015 | 12:19 PM
integfoo's Avatar
Originally Posted by integfoo' timestamp='1433571676' post='23638222
[quote name='gptoyz' timestamp='1433571039' post='23638217']
[/quote]
you think youd be able to tell the difference of 1/16 to 1/32 toe in?
Old Jun 6, 2015 | 04:40 PM
gptoyz's Avatar
I started with 1/8th total which was great for novice skill.
And when I was able to control the car needed more drive and was willing to deal with the looseness of the car; I reduced the toe to 1/16.
I plan to cut it to 1/32 on my next alignment but if the car is not predicable or too loose I will try 3/64
