Axles
Old Jun 8, 2012 | 09:04 AM
ack5252's Avatar
Default Axles
Are the OEM half shafts a standard steel (mild) or chromoly/some other alloy? I was thinking about how to build an axle that would save some weight but not sacrifice strength. Any thoughts?
Old Jun 8, 2012 | 09:37 AM
CKit's Avatar
That it'd be cheaper and easier to buy a set of upgraded axles from DSS?
Old Jun 8, 2012 | 11:23 AM
ack5252's Avatar
Yeah but I dont think they would be any lighter though (most definitely stronger I'm assuming). I am imaginig a set of axles that are made of a stronger material which would require less of the material, and thus less weight. Im not sure if thats possible though? What about an axle made out of chromoly tubing? I feel like a strong chromoly/alloy tubing with thick walls would do the trick maybe?
Old Jun 8, 2012 | 12:26 PM
speedengineer's Avatar
How come you are worried about the weight?
The axles are small diameter, and don't spin fast like engine parts, so there are no significant reductions to be made in terms of rotating inertia. I'm talking completely negligible differences here.
Now, if you're just looking to save some regular vehicle mass, I hear you, those things don't look very weight. Sounds like an expensive form of weight reduction though...
Old Jun 8, 2012 | 12:36 PM
krazik's Avatar
Administrator
Old Jun 8, 2012 | 12:49 PM
Ludedude's Avatar
Administrator
Just make them out of carbon fiber.
closetgeek
32
Oct 14, 2015 03:47 PM
crank
Dec 6, 2010 11:44 AM
s2konroids
Feb 16, 2009 06:41 AM
Nytruco
44
Jan 17, 2009 08:07 PM
BrandonS
May 13, 2003 06:37 AM
