B Street Advice/Prep
Old Jul 21, 2015 | 10:27 AM
  #31
mball19's Avatar
I have a 2006 that I have been autocrossing for about a year in BS and I have been using the following set up.
Eibach FSB set to full stiff. So far this bar is plenty stiff for the surface I run on (asphalt only). I have seen a few pictures of my car almost lifting the inside front tire around corners. I can't imagine using a stiffer bar and have had no issues with lifting the inside rear tire.
225/255 Hankook RS3s V2. I think that I would prefer 245s in the front as my car typically has neutral to understeer behavior. It is almost impossible to rotate the rear under throttle with 255s in the rear. I am running 37psi front and 35 psi rear.
I am running max camber up front (~ -1.8) with zero toe and max caster. My rear camber is matched to the front and I am running a little toe in rear.
I still have stock shocks, exhaust and brakes.
Old Jul 21, 2015 | 10:38 AM
  #32
Ham8urger's Avatar
Most of our courses here are asphalt too. Is a good rule of thumb to run your rear tires 2-3psi less than the front?
Old Jul 21, 2015 | 11:30 AM
  #33
viccath5's Avatar
Originally Posted by engifineer
Originally Posted by viccath5' timestamp='1437502116' post='23687994
interesting thread.
my setup for B street. RE-71Rs, 245/255. Gendron, 2 3/8 hollow on 3rd to softest, 0 toe and -2 camber on the front and 1/16 toe in and -2.2 camber on the rear. Re-valved Konis, usually 1/4 turn from full hard on front and 1/2 from full in rear but on rougher surfaces I add 1/4 turn from full hard. I really like the sway bar setting and the alignment but not so sure about the shocks. I haven't found any adjustment that really works much better than anything else. Not really sold on the Konis. Maybe I should go back to OEM for comparison.
I get a bit of under steer in the middle of sweepers but turns in good.
Would like to be able to get on throttle sooner coming out of sweepers. Might need to take away a bit of rear camber so I can induce a bit of oversteer. Any suggestions?
Have you tried softening the front damper rebound setting (the only setting you have on Konis)? Do it in a very large increment to test, as small changes on a damper are not always easy to feel at first. So try something a bit more dramatic and see how it works.
I always thought that the shock adjustments had more to do with initial turn in. I'll definitely try softening the front though. Thanks!
Old Jul 21, 2015 | 11:43 AM
  #34
engifineer's Avatar
They can have an effect on both for sure. Anytime the car is in transition, the shocks are having an effect. The trick is balancing the adjustments to have the right effect in both turn in and exit
Old Jul 21, 2015 | 11:48 AM
  #35
engifineer's Avatar
I cant imagine you lifting a tire with that bar, or even the stiffest Gendron most likely. I dont know any serious autocrossers that run anything less stiff than a Moddiction\Saner bar for very long. I have also never seen one lift a front tire in a BS setup even with the Gendron on full stiff. Maybe others have, but not I.
You mention you are lifting an inside REAR tire? I have never seen that on an S2000. Are you sure you didnt mean front? If lifting the inside rear, your diff is then open and I can imagine the car behaves horribly. And if you are lifting or near lifting the inside rear, you are nowhere close to lifting the inside front. You dont have enough grip to be lifting both inside wheels at once, so any lift would be mostly due to weight transfer and bar setups, which will typically lift one or the other, but not both.
Old Jul 21, 2015 | 02:45 PM
  #36
robinson's Avatar
I cant imagine you lifting a tire with that bar, or even the stiffest Gendron most likely. I dont know any serious autocrossers that run anything less stiff than a Moddiction\Saner bar for very long. I have also never seen one lift a front tire in a BS setup even with the Gendron on full stiff. Maybe others have, but not I. You mention you are lifting an inside REAR tire? I have never seen that on an S2000. Are you sure you didnt mean front? If lifting the inside rear, your diff is then open and I can imagine the car behaves horribly. And if you are lifting or near lifting the inside rear, you are nowhere close to lifting the inside front. You dont have enough grip to be lifting both inside wheels at once, so any lift would be mostly due to weight transfer and bar setups, which will typically lift one or the other, but not both.
He posted inside front tire in his post.
I've lifted an inside front with a saner on full stiff and CR shocks/springs, 04' rear bar & typical stock height alignment.
Old Jul 21, 2015 | 02:46 PM
  #37
robinson's Avatar
interesting thread. my setup for B street. RE-71Rs, 245/255. Gendron, 2 3/8 hollow on 3rd to softest, 0 toe and -2 camber on the front and 1/16 toe in and -2.2 camber on the rear. Re-valved Konis, usually 1/4 turn from full hard on front and 1/2 from full in rear but on rougher surfaces I add 1/4 turn from full hard. I really like the sway bar setting and the alignment but not so sure about the shocks. I haven't found any adjustment that really works much better than anything else. Not really sold on the Konis. Maybe I should go back to OEM for comparison. I get a bit of under steer in the middle of sweepers but turns in good. Would like to be able to get on throttle sooner coming out of sweepers. Might need to take away a bit of rear camber so I can induce a bit of oversteer. Any suggestions?
It would be good to know what year car you have to determine the rear bar you have.
Old Jul 21, 2015 | 03:33 PM
  #38
Fokker's Avatar
Car has an '07 stock according to profile and assumption of BStreet rules.
Old Jul 21, 2015 | 04:09 PM
  #39
viccath5's Avatar
Yes, profile is correct, and thanks for your help. A little history. I am in my 6th year of autocrossing, 4th with this S.. I run regional. We have a very competitive B street class. This year I am struggling to beat a vette and I need to up my game.
Old Jul 21, 2015 | 04:16 PM
  #40
robinson's Avatar
Yes, but not all OEM rear bars are the same.
I think this is an often forgotten item to list and think about.
