BBK kit differences (C43, ST40, etc)
Old May 25, 2021 | 08:13 PM
cracknut's Avatar
^ pretty much what Jakob and Matt said; however, I will qualify the consumables wear piece with this:
One more on the bandwagon. I have the ST40 kit on the current racecar and check after every event but pad thickness barely changes.
Bought the C43 kit for the new racecar because I'm going for minimum weight. However, for a trackday car not trying to meet a stupid low class minimum weight I'd follow the advice above.
Old May 26, 2021 | 05:35 AM
ajohnson's Avatar
I’ve been following this.
I use stock rears, giro disc fronts and the accord pad. Brakes last a 30-45 min sprint race without issue. Temps are very high. 800+C both front and rear with gloc r16/r12 pads. I eat rears after 2 events. Front wear seems better since using the accord of and the giros keep temps down quite a bit.
ive been looking at c43/42 kits but my rules require me to add 50lbs. It might be worth it.
Old May 26, 2021 | 08:12 PM
Bullwings's Avatar
Get the ST40 kit over the C43.
I'll leave this here - fast forward to 11:10 mark. Anecdotal, yes - but, add that to the accelerated consumables wear compared with the ST40, and it's another reason for me to stick with the tried and trued ST40 kit. Add on top of it the cheaper ST40 purchase price compared with the C43, and it really does sound like the C43 kit is a bunch of hype....
Old May 26, 2021 | 11:12 PM
ncrx's Avatar
ive got the c43 kit, i'm 4 track days in with hardly any pad wear. im running ducts front and rear with urge rears. i also find the track pads noisy but i am using the stoptech 309 streetpad when not at track and they're pretty much silent. the street pads are chamfered at the leading edges, i wonder if that helps,
Old May 27, 2021 | 09:14 AM
boyguan's Avatar
https://www.youtube.com/watch?v=J49oWNOu-nI&t=850s
So i just picked up a set of used st40, what i found interesting was the rotors i got have full float hardware, they make quite a bit of noise. I originally thought it was something wrong until i did some measurements and found the nuts stick out pretty far to allow the rotor to float. Kind of makes me wonder since the rotor holes are oblong, that this constant back and forth will elongate the holes even more.
The c43 rotors are a full float as well which makes me wonder if the design is really safe considering his rotor exploded
Old May 27, 2021 | 12:11 PM
Shift9303's Avatar
As far as I’m aware floating rotors are industry standard. The oblong holes are to allow expansion and contraction of the material with heat since brakes get hot. Theoretically they should always naturally center themselves regardless of the rotors bolt opening size as long as the hat is circular no? Also ST40s used to be cheaper but now they’re priced almost the same as C43 kits at most places.
Old May 27, 2021 | 03:22 PM
Nate Tempest's Avatar
Originally Posted by afzan
rear RX8 kits will affect the OEM brake bias, SBG's front bbk kits are meant to be paired with the rx8 rears so they retain close to OEM bias...
There are other ways to deal with brake bias and everyone has their own preferences -- just something to be aware of
You can match them with Wilwood fronts too, as long as you get the appropriate piston size (41mm iirc, with 38mm being a good match for stock rears).
Old May 27, 2021 | 03:30 PM
Originally Posted by roel03
ST40 is probably the best caliper for a daily driver since it has dust boots. C43, Wilwood, and many others do not have dust boots. That said, I haven't had any issues dailying a car with dustboot-less calipers. Avoid driving them in salt situations, though.
C43 and Wilwood Superlites use the same pad shape and have much cheaper pads than the ST40 does. I am a big Wilwood fan since replacement calipers are like $150 a pop. Ran them for over a decade now and no issues. I would never buy a ST40 kit because of the cost of consumables alone.
As for rears, either the SBG kit or the Reilly Racing mustang kit is what I would recommend. I don't like the 2-piece rear vented rotor upgrade because of the cost of rotor rings.
I had hoped that the Wilwood fronts would give me better wear than the ST40 due to the thicker pads. However I'm finding due to the smaller area of the pads, I tend to get significantly more top to bottom taper that I did with the ST40s. So brake feel is great for basically one event, and after that I have a fairly deep pedal because I effectively have to press the tapered pad flat onto the rotor. I'm going to try moving up to a higher compound to see if that helps, but yeah, so far that's been the one downside of this setup - considerably better pedal feel with the ST40s. However they ST40 kit doesn't match the SBG rears.
I wonder if there's an AP Racing caliper I could use with these AP front rotors that would have similar clamping force to the 41mm Wilwood, but a larger pad.
Edit: ah, there is a comparable AP caliper, but unsurprisingly it uses the same pad: https://www.essexparts.com/cp8350-tr...right-anodized. Guessing performance would be similar.
Edit again: I suppose the first thing I should try are some different pad compounds. I've been running GLoc R10s since I like to use the same pad for autocross, track, and driving to-from. Have an R12 that I was planning to try out already, but if that still tapers too much, might experiment with something different, like Raybestos ST43 or even ST47...
Old May 29, 2021 | 08:40 AM
RolanTHUNDER's Avatar
Originally Posted by Jakob Boedenauer
Depends on what you define as performance.
The Spoon Monoblocks are nice in the sense of using stock pads, however that's also a negative. You'll have the same problem with cracking rotors, heat management and wear as you do with stock calipers. C43s and ST40s have a higher heat capacity simply by design, the pads shape is generally larger so wear is reduced, the rotors are floating, etc.
For me, i kept stock calipers but went with Girodisc rotors and the wear has improved significantly. The next step up would be a kit like the C43 or ST40, the Spoon Monoblocks simply don't give enough benefits for the cost IMO.
Valid points to consider. Thanks
Old May 29, 2021 | 08:41 AM
I use 309's as well and I think they're great! They can take a beating and when hot they really come alive which takes some doing on the street
