Bent Carbotech pads, update
Old Jun 14, 2015 | 09:51 AM
CKit's Avatar
Default Bent Carbotech pads, update
Update to this thread:
https://www.s2ki.com/s2000/topic/753...s/page__st__25
I was having a little bent pad backing plate issue in our T3 car. Piston side.
Much improved after filing the ears and the side of the pad.
But was given a tip from a Spec Miata racer.
Just remove the side shims to give more space and eliminate any side binding at all. Looking at the shiny parts on the shims from wear even after filing, I think this is the easiest solution.
So no filing ears and just remove shims.
Picture for reference:
Old Jun 14, 2015 | 05:05 PM
decepticondc5's Avatar
Interesting that these little dudes could cause such dramatic deformation. Let us know how bad the pad knockback is if you don't mind.
Old Jun 14, 2015 | 05:31 PM
CKit's Avatar
Full club racing didn't notice any knock back or clicking.
Old Jun 15, 2015 | 03:22 AM
dan_uk's Avatar
thanks for sharing, had a lot of brake drag and rear brake issues so definitely going to try this
Old Jun 15, 2015 | 09:28 AM
Mrsideways's Avatar
Carbotech uses other peoples backing plates. I've had issues with them bending... even on the vette I ran a few weeks ago they bent.
Old Jun 15, 2015 | 09:33 AM
RedCelica's Avatar
I bent the fronts (piston side as well) on the xp9s I ran (no shims). Going XP10s this year so we'll see how they do!
Old Jun 16, 2015 | 07:37 AM
imstimpy's Avatar
What is so good about the Carbotech pads that warrants solving the bent backing plates rather than switching to another manufacturer?
Old Jun 16, 2015 | 11:56 AM
klch's Avatar
I switched from Carbotech to PFC, and realize how poorly made Carbotech are
I've personally had 3 occasion where they've used the wrong template and sent us the wrong pads for various cars (not S2000)
Old Jun 18, 2015 | 06:28 AM
shind3's Avatar
Non-corrosive brake dust.
Old Jun 18, 2015 | 06:33 AM
nissanfanatic's Avatar
I always remove the shims on any cars that I track. It is louder but I noticed the same thing with binding on various race pads.
I run Raybestos ST43 brake pads. Pretty cheap and they last forever...
