Best tire for B Street AP1
Old 12-29-2013, 11:32 AM
imarcr2's Avatar
Default Best tire for B Street AP1
Hello all,
Just wondering what the best tire for the new B Street for an AP1 on stock wheels?
Thanks
Old 12-29-2013, 12:22 PM
Requiem's Avatar
I have run Hankook RS3 tires. They have always worked well for me as I am on my second set.
Old 01-03-2014, 01:58 PM
jeffjanzen's Avatar
I hated RS3's on my AP1. I think the Z2 is ultimately faster also. Stiffer sidewall handles the pinch better. I was running 225 all around.
Old 01-03-2014, 04:11 PM
Suprglu's Avatar
I have a 2008 CR with offset wheels. It's my daily driver and I track it regularly. I run Bridgestone RE11. 225/40 17 on the front and 255/45 17 on the rears.
Old 02-17-2014, 03:02 AM
imarcr2's Avatar
Thread Revival!
On a AP1 are people running the same size tire(225) all around even though the wheels are heavily staggered?
Old 02-17-2014, 03:35 AM
SmokeyGatto's Avatar
Originally Posted by imarcr2
Thread Revival!
i run a 205 square setup on my 03
Old 02-17-2014, 05:02 AM
imarcr2's Avatar
What tire do you use?
Did you consider 225 square?
Old 02-20-2014, 07:52 PM
solos2k's Avatar
205 square? 50's or 55?
Old 02-20-2014, 10:13 PM
mLeach's Avatar
on an AP1, I'd try to find some stock width 17" wheels and run 215/235 R1Rs.
Old 02-21-2014, 12:08 AM
djsilverjohnson's Avatar
For SCCA Solo Street class the fronts would need to be 17x6.5 et55 (stock) down to ET47 (1/4" allowance)
I did some searching and the only 17x6.5 wheels I could find in that range were some wheels from Honda Accord, CR-V, or Acura CL/TL.
The rears would have to be 17x7.5 et65 (stock) down to et 57 (1/4" allowance) and I couldn't find anything in that size with the correct bolt pattern.
TireRack doesn't sell any aftermarket 17" rims narrower than 7" so OEM fronts would be the only choice. They may have 17x7.5 rims for the back in the allowable offset range, but you'd be running mismatched wheels front to rear.
I just recently purchased an '03 AP1 with Dunlop Z1's in the OEM size and will be running those in Street Class on OEM wheels with 1/4" spacers. If I were buying new, I'd run the Dunlop ZII's in 225/50/16 front and rear. The allowable rim size for that tire is 6"-8".
Quick Reply: Best tire for B Street AP1
