bolt on rollbars?
Old Jan 15, 2005 | 10:57 AM
MBurnz's Avatar
Default bolt on rollbars?
apparently if a convertible is running faster than a 13.5, the vehicle has to be equipped with a rollbar in order to pass.. i found this out after a 13.3 pass @ union grove last year, but i love this track and would not prefer to go anywhere else. well to make a long story short, i personally don't like the look of a rollbar in an s2000, so are there any rollbar units that can be easily bolted in during install and removal? basically a unit i can easily install on a day prior to going to the track, and remove when done.. install time does not matter just so as long as it doesn't take more than a day nor require any drilling/cutting into the factory plastic trim pieces.. am i asking for too much or is there a kit like this out there?
Old Jan 15, 2005 | 11:02 AM
payneinthe's Avatar
yes, you're asking too much. Check out the elda engineering bar. it's by far the best rollbar out there.
Old Jan 15, 2005 | 11:04 AM
dms2k's Avatar
The Elda bar requires some cutting of the plastic trim pieces.
Old Jan 15, 2005 | 02:18 PM
Feezy's Avatar
I think the cusco on fits your description, but I'm not ture sure how functional it is. Its looks nice though.
Old Jan 15, 2005 | 04:03 PM
Ludedude's Avatar
Administrator
Yes, it does.
Old Jan 15, 2005 | 04:05 PM
depletedUfoot's Avatar
I thought the Elda was no longer available. Not true?
Old Jan 15, 2005 | 04:07 PM
Ludedude's Avatar
Administrator
The Elda will shortly be available again if my sources are correct
Old Jan 15, 2005 | 04:15 PM
drewchie's Avatar
That's the one I'm waiting for.
The Elda bar requires minimal cutting and allows nearly everything (glove box, etc.) to function without restriction. It's by far the most elegant design if you want to keep your car street friendly. You won't need to pull it out between events, just an easily removed cross bar.
Old Jan 15, 2005 | 05:25 PM
Wael El-Dasher's Avatar
We are releasing a new run soon. Starting next Thursday Marketplace and us will be able to take pre-orders. The bars will be marketed as Version II due to some manufacturing upgrades. The basic design has not changed at all, just the manufacturing and tolerances. We are expecting March deliveries.
cheers
W
Old Jan 15, 2005 | 05:59 PM
dms2k's Avatar
cheers
W
