Close ratio gear sets
Just out of interest really, but does anyone offer replacement gear sets for the S2000?
Is anyone here using different gears?
I don't mean final drive...
I am definitely no gear expert, but I am with MB on this one, it would make more sense to only shorten the 5th, 6th gears I think. Changing the final drive and you are also shortening 1-3, or 1-4 effectively, which I don't think is ideal at all for most roads/circuits. Having more efficient top gears seems like a better idea than shortening everything.
1/2/3 are geared quite well I think. I'd like to do something with 4/5/6 to shorten them and max out at 150 ish, and really that means custom gears.
Is there anything which can be swapped from other Honda models?
I was going to look at AP2 ratios but suspect they aren't too different.
Interesting ratio comparison:
https://www.s2ki.com/s2000/topic/789116-gear-ratios/
Looks like M Factory don't do S2000 synchro gears:
http://www.teammfactory.com/close-ratio-gears_Honda
PPG make some.
PPG S2000 gear options
Far from cheap.
I don't know of any options that make sense in terms of performance/cost. For performance the best options require changing the box.
-Brian.
Far from cheap.
-Brian.
