Gear Ratios
Old May 14, 2010 | 09:46 AM
Monk In S2k's Avatar
Default Gear Ratios
I have been looking around the site for a while and have not found anything that makes a good comparison between AP1 and AP2 gear ratios. I made this spreadsheet some time ago and I had to go back and change it to work with our cars.
You can view the spreadsheet using two options:
1. If you do not have a spreadsheet program you can view it here., however there is no graph function.
2. If you have a spreadsheet program, the file can be downloaded here.
You can modify the tire size, fuel cut-off, secondary ratio, final ratio, and any of the ratios in columns C and D and the spreadsheet will automatically update.
The gears 1-5 are shorter and 6th is longer for the AP2. The shift speeds are recommended from AP2 owner’s manual (not sure if they are the same for AP1).
This is not to be used on a real world application, and you should calculate your gear ratios yourself before modifying your car.
It does not take into account any tire deformation, road conditions, and speedometer calibration. I have seen varying values from multiple locations for the gear ratio information but I think this site is the most accurate:
Powertrain
Old May 14, 2010 | 10:54 AM
buzz944's Avatar
WOW NICE WORK
Old May 14, 2010 | 11:55 AM
camuman's Avatar
ok i am pretty sure i am retarded, but i click the graph tab and its blank.
help a brotha out
Old May 14, 2010 | 12:43 PM
cenix's Avatar
thanks for sharing.
Old May 15, 2010 | 12:31 AM
H22toF20's Avatar
Good stuff.
Old May 15, 2010 | 07:05 AM
help a brotha out
For some reason Google Docs does not work well with charts so they were removed when I uploaded them. I will try to put together a file to download so it can be opened with a spreadsheet program.
Old May 15, 2010 | 09:39 AM
Saki GT's Avatar
Very cool - nice work.
Old May 16, 2010 | 09:19 AM
Rubn1out4GudLuk's Avatar
Hmm?...
I was under the assumption that ap2 transmissions have 5-6th(not just 6th) as the longer gears than the ap1 transmission?
Ap2's go to 58 mph at the top of 2nd gear while the ap1's are a little over 60 mph(this is why the the 0-60's are slower for the ap2's than ap1's, they have to shift twice to get to 60 mph).
Top of 3rd gear for an ap1 will hit 90 mph while an ap2 will only reach 80 mph.
I'm running stock wheels w/ stock size tires.
Old May 17, 2010 | 04:02 AM
help a brotha out
Original post was modified to included a link to a downloadable file.
Old May 17, 2010 | 11:37 AM
Originally Posted by Rubn1out4GudLuk,May 16 2010, 09:19 AM
Hmm?...
Your assumptions might be right. I added tire compression in the spreadsheet. A small amount makes some difference.
rmerchant3
Feb 21, 2018 10:34 AM
nglaser
Sep 23, 2010 03:31 PM
SPLNDID
Jan 31, 2008 04:05 PM
wazzurp
Jan 10, 2007 06:23 AM
Red_Devil
Apr 27, 2006 11:18 PM
