Cobalt XR2
Old Sep 29, 2007 | 03:56 AM
  #91
tinkfist's Avatar
Stop driving so hard
Old Sep 29, 2007 | 09:49 AM
  #92
BrianZ's Avatar
Originally Posted by 3312DC,Sep 29 2007, 12:48 AM
I bought them marchish but didnt put them on till halfway through this season. Im not sure if the street miles did it? but I only put on maybe 5-600... and 5 track days or so. The pads had meat left.
Ive had 2 sets of VRs, and never had any problem like this.
cracked oil pan, blown RA-1s, brake pads falling apart... not a good year for me
You drove those pads on the street? You will get horrible and pad and rotor life if they are not in the correct temp range. Sure they will still stop you, but the material was designed to be HOT.
I found out the hard way. On my H1 car I was killing pads... found out my brake ducting worked to well, I took them out and it solved the problem.
Old Sep 29, 2007 | 06:02 PM
  #93
zpeed's Avatar
So you recommend no brake duct for my PDX run with XR2 & GTS combo? I did not change out my rear and left GTS in there (lazy) for daily use. How bad can it be for the rear. It hardly any wear on the rear when I change out to GTS before the track day.
Old Sep 29, 2007 | 08:29 PM
  #94
pongydoo's Avatar
[QUOTE=zpeed,Sep 29 2007, 06:02 PM] So you recommend no brake duct for my PDX run with XR2 & GTS combo?
Old Oct 1, 2007 | 05:43 AM
  #95
RSXLNT's Avatar
My understanding is that the entire Cobalt XR series operates from ambient temperature to somewhere in the neighborhood of 1600 degrees. The ambient temperature aspect made this a kind of "breakthrough" race pad. All the others, including the Spec VR's, required minimum operating temps of 300+ degrees.
My car is a daily driver and I've only used Spec VR's, Carbotech XP12's, and now the XR2's as my full-time pad. I usually get about 9,000 miles (on the VR's and XP 12's) including half-a-dozen tracks days on a set of pads.
One of the cars Cobalt tested the XR2's on was their own daily driven Civic. You might want to speak with Andy or Glen at Cobalt about your broken pad. I'd be curious to know why they think that happened.
Old Oct 1, 2007 | 12:50 PM
  #96
GT Motoring's Avatar
Former Sponsor
LOL, i must be easy on my brakes =0( i get numerous track days on my pads.
Old Oct 1, 2007 | 03:28 PM
  #97
Voodoo_S2K's Avatar
Daily driving on track only pads will make for an early grave.
Old Oct 1, 2007 | 03:47 PM
  #98
krazik's Avatar
Administrator
no way. I've done it on cobalts for years. presently I have oem pads in my street car because I got tired of the noise and don't track the street car much.
But you can run race pads on the street just fine and they (atleast cobalts, even the VRs) work just about as good as oem.
Keep spreading the voodoo tho
Old Oct 1, 2007 | 04:04 PM
  #99
Voodoo_S2K's Avatar
I left my VR's on after my last track day. They had 3mm of pad material at that point. I went through those 3mm in less than 4 weeks of driving.
Maybe I just brake harder on the street then you do.
Old Oct 2, 2007 | 07:03 AM
  #100
BrianZ's Avatar
It must be a YMMV thing.
I'm not saying street driving race pads does not work(Colbalt XR2). I'm saying they are out their working heat range and increased pad and rotor wear will happen.
