corner balanced yesterday ?
Originally Posted by WynnS123,Apr 21 2009, 06:24 AM
Does alignment settings change if you just change out the front sway bar?
If you change the sway bar and have adustable end links and you follow the post I wrote above:
* there will be no preload on the bar and you will be fine. That is assuming you did not have a preloaded sway bar on the car that you removed to install the new one.
* If the either the new or the old bar is preloaded you will change the corner weights on the car which will change the alignment.
I use a set of Long Acre Racing proffessional corner weight scales. I use them on a floor and level the pads to each other.
Like these but an older version:
http://www.longacreracing.com/catalo...?id=43&catid=1
If I was to get a new set I think these are the ones to get:
http://www.intercomp-racing.com/Products/S..._SYSTEM_903.cfm
Mark
Mark
I used intercomp scales and yes i have acess to an allignment rack . Re alligned last night setttings are
Camber FL- 2.0 FR -2.0 maxed
Castor FL 6.25 FR 6.25 maxed
Toe FL 0 FR 0
Rear Camber Rl-2.5 RR-2.5
Rear toe RL +. 40 frozen ut will correct with new toe rods
RR Toe .+12
so i got just what i wanted besides let rear toe is a lil out but total toe was still in factory spec , we will see how it feels . Thanks for the help
Toe FL 0 FR 0
RR Toe .+12
db17k
Apr 15, 2007 03:49 PM
