Dry Sump......
Old Oct 28, 2004 | 05:36 PM
  #21
ellisnc's Avatar
I'll buy one if it comes with a carburated 350!!!
I'm hardcore, but not that hardcore...
Good luck, looking forward to pictures of at least your cars...
Old Oct 28, 2004 | 05:53 PM
  #22
Ludedude's Avatar
Administrator
Originally Posted by slick rick,Oct 28 2004, 06:24 PM
I'd be interested if it was in the 1500 range
Dude, give me a call (phone # on the GFL site) so I can take care of that piece for you.
J.P.
Old Oct 28, 2004 | 06:26 PM
  #23
davepk's Avatar
$1500 range??
Dude! Take a look around and price out the 3 main components, pump, pan and tank. Hell, the pump is around $700 and the pan is around $400. Add to that the tank, belt drive hw, oil filter hw, AN fittings and hose. Oh and dont forget the mounting bracket and the oem oil pump block off plate. I know i'm forgetting a few items.
Old Oct 28, 2004 | 06:54 PM
  #24
Gernby's Avatar
Former Sponsor
... like the custom engine mounts ...
EDIT: come to think of it, couldn't you sell the engine mounts as an "option"?
Old Oct 28, 2004 | 07:08 PM
  #25
krazik's Avatar
Administrator
seeing how a new motor is a bit under 5k new or 2.5k used its a drop in the bucket.
The engine mounts won't do you any good w/o the oil pan.
  #26
davepk's Avatar
I've been toying around in my head an idea for a hybrid wetsump/drysump setup that should be quite a bit less then what we are doing now.
Basicly add an external single stage pump and drysump tank and keep the oem pump as a scavenge pump.
Old Oct 28, 2004 | 08:05 PM
  #27
Doug Hayashi's Avatar
Why do you need to lower the motor?
Can the sump stuff work without lowering the motor?
-Doug
Old Oct 28, 2004 | 08:12 PM
  #28
Ludedude's Avatar
Administrator
Probably to solve the clearance issues for some componentry.
Old Oct 28, 2004 | 08:59 PM
  #29
Slows2k's Avatar
I'd look into the prop shaft angles being to great if you lower the engine too much, as well as exhaust clearance. Just some food for thought.
A dry sump is too hardcore for me, but I sure would like to see one.
Old Oct 28, 2004 | 09:04 PM
  #30
davepk's Avatar
Lowering the motor helps to lower the CG of the car. Its something like for every inch you lower 100lbs you increase your lateral G limit by 0.1g I probably have the values wrong but you get the idea. Its one of the primary benifits of going to a dry sump system.
