Evasive-SPEC Eibach Multi-Pro R2
I have a a set of SRC in my '05 (2900lbs), which has become mostly a street car, and a set of R2's in my '07 (2700lbs) track car. The R2's with stiffer springs (1000lb square) seem much more compliant (softer high speed bump?) to me than the SRC. I do wish that the R2's could be a bit farther from the bump stops, RCA's are mandatory with the R2's.
Yes, ots valving, and I purchased them used, so even though my SRC's show no signs of needing rebuild, I can't rightly compare the R2's to Evasive or CSG spec, or even known good new ots SRC's. Another note: I think that there's more room for error with the knobs on the R2's than the SRC's.
For those of you who have these, did you purchase the OTS 900lbs F/R setup or did you go with something different? What is your overall review for street/autox/track days? If you didn't go with the 900 setup what did you go with and why?
Thanks guys
Thanks guys
