Forgestar F14 17x10, data thread
Old May 1, 2017 | 04:23 PM
  #431
Kenny_Stang's Avatar
Originally Posted by usafstud
I dont think I'll have the time to install ohlins coilover, front sway bars, BBK,fenders rolled and alignment/corner balanced in the next 15 days before my next track day. So I plan to get the BBKs on, front sway bars installed and try these new wheels and rs-3 tires for the next track day mid May.
will thses wheels w/255 still cause rubbing issue with stock MY00 shocks/springs? My current alignment is roughly -2 to -2.5 degrees front and back.
What size wheels did you get?
Old May 1, 2017 | 04:44 PM
  #432
usafstud's Avatar
17x10 +55 with 255 rs3 tires
Old May 1, 2017 | 05:00 PM
  #433
I think you'll be fine at stock ride height with those specs, hard to tell100% for sure as I doubt many are running that exact setup. If you plan to lower the car, you will need
to do a fender roll and tab relocation.
Old May 1, 2017 | 06:00 PM
  #434
usafstud's Avatar
i dont plan to go 1-1.5" lower. I have a pretty steep driveway.
Old Jun 4, 2017 | 03:28 PM
  #435
usafstud's Avatar
So, my 17x10 +55 rims rub on to the stock shocks when making sharp(er) turns. It contacts on the top hat right above the spring. Anyone else rubbing the stock shocks? I'm going to have my ohlins dfv installed and aligned in the next few days. I plan to have 2.7-3 camber all around while being at stockish height to avoid bumpster issues. Hopefully the rubbing goings away since the Ohlins should be skinner than the oem shocks.
Thoughts/experience?
Old Jun 4, 2017 | 03:34 PM
  #436
pkh's Avatar
pkh
My 17x10 +55 rub the upper control arm at full lock 6mm spacer. It hasn't been much of an issue for me I just don't turn all the way...
Besides that, I have been perfectly happy ... waiting for my backup set of Forgestars to arrive
Old Jun 5, 2017 | 05:23 AM
  #437
King Tut's Avatar
They never rubbed my Ohlins or my Penskes. Definitely never advisable to go full lock with really large wheels. I use mine only for the track, and I don't remember them ever contacting the control arms.
Old Jun 16, 2017 | 08:56 AM
  #438
lt24's Avatar
I'm still new to wheel fitment, wondering if anyone can help me out. I want to replace my stock wheels with F14s. My car is completely stock, no fender/suspension mods. My goal is to get keep it that way for the time being while getting more rubber on the road. I basically want a plug/play replacement for stock wheels without worrying about rubbing anything. Can you recommend the widest wheel and offset I should get? It can be staggered or non staggered. I occasionally autox maybe 2-3x a year for fun, but otherwise it's just a street car. Just looking for a little change without having to do much and I decided these wheels would be a good choice because of the custom offsets. Thanks.
Edit: sorry I just realized this was a racing thread. But if anyone could still advise, I'd appreciate it.
Old Jun 16, 2017 | 11:52 AM
  #439
slowd16's Avatar
17x9 +62 wheels all around are the driods youre looking for...
Old Jun 16, 2017 | 01:58 PM
  #440
usafstud's Avatar
So my wheels (17x10 +55) don't rub the ohlins at -3 camber like they rubbed the oem shocks at -2 - 2.5 camber at full lock. But now it rubs the 2.5" brake ducts at full lock. Minor issue when moving around paddock or drive way.
