Forgestar F14 17x10, data thread
Old Oct 25, 2016 | 05:10 AM
  #411
Cpt. Spock's Avatar
Originally Posted by pkh
I ordered a set 17x10 +55 Matte Black
Hoping it all fits!
It will, provided you modify the fenders/fender liner a tad, and depending on how low you are.
Old Apr 25, 2017 | 06:04 PM
  #412
usafstud's Avatar
Any updates on folks using thr gorilla extended lug nuts with some (extended) track miles?
i prefer not have to run extended studs if these gorillia extended lug nuts are feasible on the track
Old Apr 25, 2017 | 06:24 PM
  #413
Kenny_Stang's Avatar
I've used them for the last year, that includes 10-11 track days and approximately 800 track miles (and about 2000 street miles). Have had no issues with the lugs, they have worked flawlessly and I have not broken any studs. The wheels also have held up fine during that time, but they are they thicker spoke version.
Old Apr 25, 2017 | 06:40 PM
  #414
ndogg's Avatar
How is an extended lug nut a workaround for not having a long enough stud?
Old Apr 29, 2017 | 07:26 AM
  #415
usafstud's Avatar
Is it normal for this to fall off the back of the hun? Is it a piece if the eccentic hub? Do I need to worru about replacing it or having the piece back on?
It has zero miles on it, i just mounted it on the car to check how much fender rolling it may need.
Old Apr 29, 2017 | 08:56 AM
  #416
TerminatioN's Avatar
That is the hub centric ring. It helps keep the wheel centered. While not 100% required most people recommend using them if you can... especially if you already have them.
But yes it is normal for them to come off sometimes. They are not physically attached in any way. Just held in by friction.
Old Apr 29, 2017 | 09:09 AM
  #417
usafstud's Avatar
Is it part of the hub centric ring or is that the whole ring?
Old Apr 29, 2017 | 09:10 AM
  #418
usafstud's Avatar
How much of the fender needs to be rolled? Front and back or just fronts?
Old Apr 29, 2017 | 10:03 AM
  #419
That piece of plastic is the whole hub centric ring. If you went to a store and bought a hub centric ring that is all they would give you.
Old Apr 29, 2017 | 10:17 AM
  #420
The extended lugnuts used here do not extend further from the seat of the nut, but the shank extends further into the stud so you get more holding power (more lug nut on the stud length).
