Front RCA issue
Old Mar 11, 2013 | 11:21 AM
MB's Avatar
MB
Member
Default Front RCA issue
Hi all, I have hardrace front and rear roll centre adjusters fitted and ran into a problem with geo setup today and was looking for comments.
Before RCA I had:
Camber FR -3 deg
Camber Rear -2.3 deg / mins
Toe FR 0
Toe rear 0.2 deg total
Caster 6.5
After fitting we could only get -2.4 deg / mins on the rear... So it wouldn't go more +ve ie we could get more -ve but no more +ve. I can live with that and we got the toe where we want it.
On the front it was worse but the opposite. The most camber we could get even by playing with the caster was 1.2 deg / mins. That was the end of the adjuster and couldn't get it anywhere near -3
I would have though the RCA would actually push the lower wishbone back up and therefore allow more -ve camber?
Almost certain they are fitted right.
Anyone come across this?
Old Mar 11, 2013 | 11:28 AM
ryangrow's Avatar
Can you get a picture from the bottom up, there is different kits for the RCAs, if I recall, one of them does not increase the camber.
It is easy to tell since the 2 bolts will be offset from the center.
Old Mar 11, 2013 | 11:39 AM
odb812's Avatar
Could you clarify before and after from a parts perspective? From what I gather, you have the hardrace 6621 offset balljoint and you had it on your car without the optional RCA plate with -3 deg camber. Then you added the RCA plate and now you can only get -1.2 deg camber. Is this right?
Was the balljoint put back on backwards? That what I'd guess since you're now getting less negative camber than stock.
I'd guess the same, but it would be so slight that you wouldn't be able to measure the difference.
Old Mar 11, 2013 | 11:46 AM
berny2435's Avatar
did you get the "offset" RCA?
If you did, you likely put the front RCA ball joints in backwards. The larger hump needs to go towards the inside of the car so that the holes where the hub bolts up are further offset to the outside of the suspension.
I happened to do this on my first install as well. They sort of go in opposite of how it looks like it should go if you keep looking a the adjusters the opposite way they go in the car. remember that you want to push the bottom of the knuckle outward. To do this, the attachment point of the knuckle needs to be further away from the inside of the car.
The installation of the front RCA will raise the car and decrease camber as well.
Old Mar 11, 2013 | 11:50 AM
odb812's Avatar
Like this:
Old Mar 11, 2013 | 12:57 PM
MB's Avatar
MB
Member
Thanks for all the replies, I appreciate it
Ive got the offset ones, pretty sure.
Hi, no I just had the OEM balljoint and changed it for the Hardrace RCA and ball joint at the same time
Great info, and sounds like what OBD812 is suggesting, it might be fitted the wrong way. I think we fitted it so it aligned with the shape of the mointing point, which from what you say is the opposite to how it should be.
Will try and swap it tomorrow and see what happens
Thanks again!
Old Mar 11, 2013 | 01:02 PM
MB's Avatar
MB
Member
Like this:
That pic is a big help
Old Mar 13, 2013 | 12:46 PM
GT Motoring's Avatar
Former Sponsor
Definitely looks installed backwards to me.
Old Mar 13, 2013 | 02:36 PM
MB's Avatar
MB
Member
Yep, all sorted now I think! Car is in for geo now but 'looks' right
Apex1.0
Aug 23, 2014 08:57 AM
madness
Feb 14, 2011 03:50 PM
unclefester
Oct 31, 2010 08:27 AM
Wombo
May 17, 2009 01:03 AM
r8byb
Mar 17, 2009 11:00 AM
