Front Sway Bar
Originally Posted by EternalLx,Dec 20 2007, 05:16 PM
Hmmm... would this make some sort of sense then?
I have KW V3s.. If i sofen the rebound rate for a better ride but that would cause it to roll more correct? and if am lowered too much I will scrape the fenderwell.
Can I use siffer sway bars front and rear to reduce the roll while cornering and maintain a better ride going straight?
The Cusco bar is very heavy. Currently, I am running REO1R's and beat competitors on R-Comps. I love that.
But I read here that the Cusco is not stiff enough for R-Comps, is this true? What front bar should I get? Will all my tuning be thrown out the window when I switch to Hoosiers?
Don't assume your bar is too soft just because AS guys are running uber-stiff ones. With aftermarket suspension, things change, so you might be ok with a softer bar. Are you lifting the inside-rear wheel at autox and losing time burning rubber? If so, you need a stiffer front bar.
I spoke with Bill today. He cannot go any lower on price for two reasons: First, the center section simply costs more from his supplier than the smaller bars he regularly sells, and the arms may require some extra work for proper fitment. Second, materials prices have increased slightly as of the new year.
I'm going to cut the GB off as of tomorrow (Saturday, Jan12) at 11:59pm and begin the order process so we can all get our bars in March. If you've confirmed your interest by then, you'll be receiving an email from me soon with payment details, etc.
