Front Sway Bar Autox Question
Originally Posted by rlaifatt' date='Feb 7 2005, 05:01 PM
How do I learn the fast-in fast-out technique?
I think that just about sums up the answer to your question
The bar will reduce the amount of sway/tipping and keep the rear inside wheel on the ground if you are getting any wheel spin on stock rubber. With r compounds the tipping increases and the inside rear wheel will lift inducing rear wheel spin and the bar will reduce the amount of tipping/sway keeping the rear planted. Grendon solid at one off full stiff is my lucky setting. I run S03's in rain and A3so4's when dry and alignments found in the auto-x racing FAQ.
