Front Wheelwell Lining
Old Mar 8, 2003 | 07:46 AM
cdelena's Avatar
Originally posted by sfphinkterMC
one solution is to cut out area and reweld a concave plate giving you room. i think i need to do that as well.
I'm not sure what you guys are talking about. I have burned pretty good holes in both sides and I don't see anything to cut without having holes on both sides of the hood. Don't think it has much to do with the tabs, this is all about ride height, spring rate, and body movement under high gee loads. On my car I don't lower the front more than one inch, have higher rate springs, Mugen bar, stiffen the shocks considerably for the track, and have minimized but not eliminated rubbing when running 225 Victos.
Old Mar 8, 2003 | 10:52 AM
airsport's Avatar
when I run 225/245 kumho's on stock rims with a 1.25" saner solid bar I rub the liner also. Usually knock out the plastic insert that holds the liner on the fender lip. I've also burned a hole throught it...
So it isn't just proper offset. BTW the car is lowered .75"
Old Mar 8, 2003 | 01:04 PM
Ludedude's Avatar
Administrator
Ok, I guess I learned something today. Thanks a lot for that interesting piece of data.
Rev9K27
Aug 8, 2011 04:45 PM
rikkilambo
Sep 22, 2010 12:41 PM
josserman
Aug 11, 2010 06:42 AM
s2k aok
Jul 29, 2008 12:06 AM
Kremlin
Jun 12, 2006 04:46 PM
