Goodridge lines issue........
Old Dec 20, 2008 | 01:39 PM
chimmike's Avatar
Default Goodridge lines issue........
I installed the goodridge lines today on my S.
I'm getting leaking out of the top part where the braided line connects to the hard line. I've tightened it fully, and it's still leaking.
Anyone else had this issue? I'm thinking of trying some teflon tape to fix it, but right now, I'm curious why it would do this at all.
And it happens on ALL FOUR!
Old Dec 20, 2008 | 02:13 PM
coldrsx's Avatar
^did you over torque?
Old Dec 20, 2008 | 02:49 PM
INTJ's Avatar
Never had this problem. I did use the special open ended wrenches...
Old Dec 20, 2008 | 07:05 PM
chimmike's Avatar
I did too. that has nothing to do with it, IMO.
they're simply leaking under pressure.
My only guess would be to use teflon tape?
Old Dec 20, 2008 | 07:13 PM
godmachine's Avatar
what kinda fittings are they ? To tighten fittings you should put them on as far as you can by hand then give 1/4 to 1/2 turn and thats it.
Old Dec 20, 2008 | 07:42 PM
Stratocaster's Avatar
If they leak, don't use them. There is nothing you can add to fix them.
Old Dec 20, 2008 | 07:55 PM
godmachine's Avatar
Well if for some reason there NPT fittings they need some kinda pipe dope or teflon tape . Thats what I was getting at
Old Dec 20, 2008 | 08:23 PM
EternalLx's Avatar
I have them on my S no problems at all.
what year is your S? MY06+ have different fittings than pre-MY06
maybe you got the wrong ones?
Old Dec 20, 2008 | 08:51 PM
I know where you were coming from. Your install sounded like it went just fine. The OP on the other hand sounds like he has a bad set of lines.
Old Dec 20, 2008 | 09:11 PM
mikegarrison's Avatar
Using teflon tape or pipe dope is good practice.
That doesn't mean not using it is necessarily the source of the OP's problem.
