Goodridge lines issue........
Old Dec 30, 2008 | 02:01 PM
  #21
chimmike's Avatar
Had to. I've never had to before on other cars, but this time, I had to use teflon tape. The lines were leaking through the threads with the goodridge stainless lines. I'm disappointed in that, but I made sure the tape was installed in such a way that it cannot get into clog the fluid.
Finally got it bled and done and it feels good.
Old Dec 30, 2008 | 02:49 PM
  #22
AnthonyD1978's Avatar
you stuck a band-aid on defective brake lines if you ask me....not trying to be an ass, but you should really replace the defective lines. maybe you got a bad batch....are you sure they didn't quit leaking because you uninstalled and reinstalled them better when you applied the tape the 2nd time?
Old Dec 30, 2008 | 03:24 PM
  #23
chimmike's Avatar
nope, because after the first time they leaked, I removed and reinstalled them again, the same way I did each time. Finally with the teflon, they're fixed.
I've already gone through almost 2 bottles of motul fluid thanks to these lines. Now that I've got 'em working fine, I'm not going to screw with 'em anymore.
Old Dec 30, 2008 | 03:31 PM
  #24
godmachine's Avatar
Originally Posted by AnthonyD1978' date='Dec 30 2008, 03:35 PM
thank godmachine someone on here said NOT to use teflon tape on brake lines...
fixed
Old Dec 30, 2008 | 04:23 PM
  #25
Billj747's Avatar
Originally Posted by coldrsx' date='Dec 20 2008, 03:13 PM
^did you over torque?
+1
Old Dec 30, 2008 | 04:30 PM
  #26
+2
Old Dec 30, 2008 | 06:08 PM
  #27
bellwilliam's Avatar
reason to NEVER use teflon tape is because if a piece of tape ever get lodged in the line, you will lose brake.
Old Dec 30, 2008 | 06:49 PM
  #28
Billj747's Avatar
I'm pretty sure the brake fluid would eat the teflon tape anyway.. i'm not sure about teflon causing a brake failure...
Old Dec 30, 2008 | 06:53 PM
  #29
chimmike's Avatar
No, I did not overtorque. There is no overtorquing the portion I'm talking about anyways.
Old Dec 30, 2008 | 06:58 PM
  #30
mikegarrison's Avatar
My brake hoses are made of teflon. ("Stainless steel" hoses are teflon hoses with a braided stainless jacket.) Brake fluid will not eat the teflon tape.
But as was pointed out earlier, the seal is not the threads, it's a compression seal. So there is no reason to use tape, and it would never touch the fluid anyway.
