handling issue
Originally Posted by krazik' date='Mar 16 2007, 10:23 AM
I totally disagree. -3 is about perfect in the back and about -4 in the front. even on stock wheels. You don't give up contact patch in a corner w/ those numbers.
However, I only had about 2.25 on the front before, and now they are up at about 3 also.
Keep in mind, I'm running stock tire sizes rather than race car tire sizes. For now, anyway.
Video (51.4M!) of a couple of laps and then the spin.
https://www.s2ki.com/forums/index.php?showtopic=472049
Try stiffen up the chassis, this well reduce undamped wheel rate. The car well be much easier to drive at high speed corners. The S2k is a front mid engine car, I feel the engine bay area is the weak link of the chassis.
What specifically would you recommend doing to stiffen it up?
Try Cusco 3pc. Chassis floor bar and S2X 4-Pt. Struct Bar first. It's not a expensive mod. I got it used. very easy to install.
Inner fender brace helps too. But try the floor bar and x type 2pc struct bar first and see how the car react.
Inspected everything today. It all looks good except the driver's side rear diff mount (the fluid-filled rubber part) obviously burst a seal or cracked or something. It's hard to see how that might have caused a handling issue. And I have no idea how long ago that happened, since I don't remember the last time I inspected that area. But I suspect it's probably recent, since everything is still wet.
It's been pointed out to me that these tires are nearly a year old, and were well used (I corded one on Wed, but it was one of the fronts -- if it had been a rear that would have explained things nicely).
Oh well. We'll see what happens.
