Hard Dog roll bar with OEM hardtop
Hi,
I'm planning to buy the Hard Dog roll bar (http://www.bethania-garage.com/s2000.htm) model number S2DH.
I spoke to Berthania Garage about the install and they claim you have to modify the levers that close the hardtop because they won't clear the bar. They recommended cutting and re-welding at a different angle.
Anyone running this roll bar and have experience with installing it in a car with an OEM hardtop (I'm assuming my CR hardtop is the same as any S2000 hardtop)???
Is there a way to do it yourself so you don't have to pay a shop to modify the levers?
Thanks,
Fil
Thanks,
Fil
It will involve some cutting and welding. If you can't do that yourself, then the answer is no.
But it's not a big deal.
On my car we just cut the levers off completely and welded a nut onto the cam mechanism, so a swivel wrench can be used instead of the levers.
I modified my handles without cutting them. Unbolt the latch mechanism from the top and put it in a vise. Then take a floor jack handle or other long pipe and slip it over the latch handle. Bend the handle so that it is almost 90degees. I think it's normally around 45 degrees. Then reinstall the latches. I was actually surprised how easily it worked.
