hard dog rollbar question
Old Aug 14, 2013 | 12:16 PM
c_lester88's Avatar
So scca and all the others won't even let you run hpde without harness and seat? I've run nasa without even having a rollbar but was hoping to get one so I could run with scca thscc and others. And eventually get into time trials and all.
Old Aug 14, 2013 | 12:38 PM
JJ7's Avatar
JJ7
Originally Posted by ScandinavianFlick
Originally Posted by JJ7' timestamp='1376506946' post='22724391
Safety equipment isnt mix n match. Rollbar, harness, HANS and seat OR OEM 3pt. Not pick 2 or 3. Otherwise your likely making your car less safe in most all situations.
IMO, a HANS is a good idea, especially as you start to pick up speed, but it's not a must-have for HPDE and for very inexperienced drivers it can be a safety risk as it cuts down on vision and therefore awareness.
Again, just my opinion, and I certainly wouldn't go wheel-to-wheel without one.
It cuts down on vision when Im backing up in the paddock, but not on the track at all. My opinion on safety equipment is, hopefully you'll never need it, but if you do you want it to work as intended. I'd rather run 3pt and airbag over harness, rollbar and no HANS from a safety standpoint.
Old Aug 15, 2013 | 06:30 AM
rohde88's Avatar
what about a rollbar mandates HANS? thats two unrelated safety items
Old Aug 15, 2013 | 07:09 AM
ScandinavianFlick's Avatar
Rollbar dictates harnesses (most of the time), and harnesses have less "give" in them than a three-point belt. They are therefore more likely to result in a neck injury in a direct frontal crash.
Old Aug 15, 2013 | 07:13 AM
rohde88's Avatar
Originally Posted by rohde88' timestamp='1376577032' post='22725790
[quote name='JJ7' timestamp='1376506946' post='22724391']
[/quote]
I have a rollbar with padding and 3 point belts. I'm assuming this is your "most of the time" but then its not always the case that rollbar=HANs
Old Aug 15, 2013 | 07:31 AM
SlowTeg's Avatar
NASA will allow it, but SCCA, PCA, BMWCCA, and THSCC all require harnesses.
Interesting.. fortunately for me I think there are enough events between NASA and other organizations for me to get my fill of track events. So I take it SCCA, PCA, etc. allow 3 point belts for cars with OEM hardtops, harnesses are only required if you have an aftermarket rollbar?
Old Aug 15, 2013 | 08:51 AM
Good question.
For those organizations, no additional safety equipment is mandated for cars with a structure that provides significant rollover protection. The "roadster bars" on Loti, Vipers, Vettes, etc fall into this category. Most removable hardtops do not, especially the s2k's. Unfortunately, in a rollover it's only there to fold itself neatly around what's left of your skull
Sorry to be gruesome, but the crashworthiness of the OEM top is a persistent myth that needs dispelling.
Old Aug 15, 2013 | 09:26 AM
SlowTeg's Avatar
[Sorry to be gruesome, but the crashworthiness of the OEM top is a persistent myth that needs dispelling.
Ha I hear you. Looking at how the hardtop mounts it doesn't take a genius to figure out it'd probably do more harm than good in a real rollover (without a rollbar, heck, even with one I don't know how safe it'd be). I guess I should've said non-convertibles..
Old Aug 15, 2013 | 11:40 AM
Driven's Avatar
Originally Posted by SlowTeg' timestamp='1376504019' post='22724256
[quote name='ScandinavianFlick' timestamp='1376503415' post='22724228']
Sorry, I should have also specified that most organizations will not let you run an aftermarket roll bar with 3-point belts. You'll need race seats and harnesses with it.
Is this for most casual HPDE's or is this only for more serious time trials? I can understand the safety concern on the street with an aftermarket roll bar, but on the track you're always wearing a helmet..? I'm getting a rollbar but am planning/hoping to participate in many HPDE's. I thought the rollbar qualified you to run at most tracks and events..?
[/quote]
This is region specific. Of the three different regions I've ran with in PCA, they didn't require that you have a harness and a race seat, if using a rollbar.
[/quote]
Not to confuse anyone, you CAN run a harness without a HNRS system... it's just not advisable.
Old Aug 15, 2013 | 02:34 PM
duffman13's Avatar
Originally Posted by c_lester88
Thank you for your replies, I'm trying to stay away from taking out the interior peices as of now although I know I'll want a harness and all before long, I guess I could always get one welded in later on after I convince myself to take the interior peices out.
Regardless of what you want it to look like when you're done, you will have to remove the trim to install the bar in the first place, and they never go back in the same...
You'll also have to trim parts of the plastics as well in order to have the bars pass through them.
If you get a harness bar at a later date, you'll also have to remove the bar in its entirety to have it re-powdercoated as well. Your best bet is to just get the bar with all of the options (lower harness, single or double diagonal - your choice!), and just remove and store your interior plastics for if you ever want to sell the bar and reinstall them.
