Heel Toe Pedal
Old Jan 10, 2013 | 11:20 AM
wildkart's Avatar
Default Heel Toe Pedal
I am making a new gas pedal for easier heel toe..
I made the pedal 1" longer and 1" wider.. what do you think? Getting ready to cut it out on the C&C Machine.
Thoughts?
Old Jan 10, 2013 | 12:27 PM
robrob's Avatar
Looking at my setup it does look like your pedal at 1" longer and 1" wider will work well:
Before you drill make sure the bottom of the pedal isn't interfering with full pedal travel.
Old Jan 10, 2013 | 01:05 PM
wildkart's Avatar
yeah, we made a cut out of the pedal first and stuck it over the existing pedal to make sure it did not touch the floor when the pedal was at full throttle.
It had a good amount of room to clear it.
Old Jan 10, 2013 | 03:41 PM
CKit's Avatar
What are you towing?
Old Jan 10, 2013 | 05:09 PM
macr88's Avatar
He might be missing a toe and can't walk so he needs a tow
Old Jan 10, 2013 | 05:21 PM
andrewhake's Avatar
The text on the pedal makes the title of this thread even more mind blowing.
Old Jan 10, 2013 | 05:35 PM
CKit's Avatar
But check it out... when you look at it on the original picture, the W looks like an E..... JENIOUS!
Old Jan 10, 2013 | 05:43 PM
wildkart's Avatar
Yeah ok.. I screwed up the title, was at work trying to post it without anyone knowing.. the toe on the pedal design is right it was drawn like that on purpose..
Old Jan 10, 2013 | 06:03 PM
jaundice's Avatar
Are you going to sell these? I would be interested.
Sent from my iPad using Tapatalk HD
JJ7's Avatar
JJ7
My pedal is exactly like robrobs. Its already really close to the brake pedal. I don't think you should make it any wider than that. .02
