Heel Toe Pedal
Old Jan 13, 2013 | 12:33 PM
  #31
josh7owens's Avatar
During braking my foot is slightly off the floor to heel-toe, to roll my heel over with it on the ground I would need some sort of pedal extention as posted about here. Maybe I need to video it one day and analize it.
Heres a video of a downshift, I'll post a couple but I like this one due to the 1.1+ Gs pulled on every turn on a slick surface, awesome! I'm having to go back into my videos to find them because in Tims CR I never needed to downshift, power all the time!
https://vimeo.com/49562177
https://vimeo.com/47417166
https://vimeo.com/45405573
Old Jan 13, 2013 | 01:06 PM
  #32
s2kreeper's Avatar
Originally Posted by robrob
Originally Posted by c32b' timestamp='1358074442' post='22263534
Side of the foot method on stock pedals works fine for me. Do u really need those extensions?
I do. I use the "heel on the floor and roll the right side of the foot" method and couldn't do it without modding the pedals. This subject has been beaten to death in other heel-and-toe threads. You have much more fine muscle control on the brake pedal with your heel planted during braking.
This is great info for me, thanks for sharing your setup. My 944 and e36 before this s I could easily do this, and the s is just a little too spaced out for me to do it comfortably without having to worry about slipping off the gas. I'll be making one of these soon
Old Jan 13, 2013 | 01:10 PM
  #33
s2kreeper's Avatar
Off topic, I noticed you have mono-flex windshield wipers like I do, and was wondering if you have the same issue of the passenger side one not being down all the way on the side closest to the fender. The window has crazy amount of curves
Old Jan 15, 2013 | 03:13 PM
  #34
gerry100's Avatar
Similiar devices used on a lot of old 911s.
I need a slightly wider Gpedal to H&T smoothly and quickly in the s2k
Keep us posted.
Old Jan 15, 2013 | 03:34 PM
  #35
josh7owens's Avatar
They seem to work fine
Old Jan 15, 2013 | 04:39 PM
  #36
odb812's Avatar
I'm the opposite. I have an extension on my 944 but not on my S. I typically hit the throttle towards the bottom when I heel-toe and since the 944 pedal is hinged on the bottom, it takes more force. All the extension does is move the point my foot first hits the throttle up higher so it requires less effort.
Old Jan 16, 2013 | 12:40 PM
  #37
limbo's Avatar
I need an larger pedal as well. In order to accomplish heel-toe now I have to lift my heel off carpet which is not ideal. Just ordered a gas pedal only from SRP for $40.
http://www.srpracing.com/pd-s2000.cfm
ponq
Dec 4, 2018 01:55 PM
jarod
Jan 9, 2007 11:26 AM
XtymourX
Aug 22, 2005 12:52 PM
QuikSilver
Mar 21, 2001 03:48 PM
Bob Moss
Mar 10, 2001 10:42 AM
