Help with oversteer on negative cambered corners
Measure your ride height from the top of the fender to the center of the wheel.
Adding a larger front sway will stabilize the rear. The front sway will keep the front from rotating as much, therefore keeping the rear wheels planted instead of picking up the inside wheel on corners. Adding too much front bar can cause unwanted understeer, I recommend the Gendron since it's adjustible.
Originally Posted by thanasis11' timestamp='1357837425' post='22258211
Monoflex settings are 10 clicks from hardest front, 12 clicks for rear.
Why would I want to mess with the front sway bar? The front end is fine. I dont want to remove grip from the front.
If the car is oversteering, there's more grip up front than in back.
Adding a bar doesn't simply "remove grip from the front". It effectively ADDS grip to the rear by alleviating the load on the outside rear.
Originally Posted by s2000Junky' timestamp='1357839285' post='22258290
[quote name='thanasis11' timestamp='1357837425' post='22258211']
[/quote]
Its not the best way to achieve grip in the rear however so in my book its a band aid. Adding more grip in back without stiffening the front is the first and best solution without compromising front handing and or grip, you are removing grip from the front, or it wouldn’t be effective in what your trying to achieve. You need to think outside your box a little bit. If more tire isnt possible in back, then other options should be explored, such as sway bars, but its a compromise that may not have to be made.
Look, lets focus on the net effects of sway bars instead of the idiosyncrasies, sway bars effect weight transfer, weight transfer effects traction on a given end, the OP is experience lack of rear traction, so your telling him through utilization of a stiffer front sway to remove weight transfer from the front to the rear tires, effectively re balancing the cars traction, so now not only is the OP experiencing reduced traction from the rear then he was previously, your now inferring that he should reduce traction up front to re balance the cars adhesion at the limit, so now he is further compounding his available lack of traction at both ends of the car rather then just the rear. Why don’t we focus on how to regain the integrity of the rear solely and bring the whole car up to a higher level?
Originally Posted by ZDan' timestamp='1357841722' post='22258409
Totally disagree with the notion that a stiffer front bar merely reduces front grip, or that a softer rear bare would merely add rear grip. Either mod affects grip at BOTH ends of the car.
A stiffer front bar increases lateral transfer in front, and reduces it in the back by the same amount.
Total lateral weight transfer is ONLY affected by track width, c.g. height, and cornering g's.
dude Zdan with all due respect your way over complicating things. Its very simple. As a base platform, stiffer rear sway and weaker front sway biases traction to the front making the car tail happy/loss of traction fist at the limit. Stiffer front sway and weaker rear holds the opposite true. Its proven in our very own car design between 00-01 ap1's and ap2's. You want to get into wheel lift and other variables to overcomplicate a simple issue, that’s your prerogative, but its counter productive. The best solution for the OP here as far as I see given his info is returning the rear toe more positive as it was previously, or add more tire in back. Leave the front alone. You change one thing and you effect another, I say let’s focus on the end of the car that is lacking first.
