Helper spring above or below main spring?
i havent found a reason why its not even but i think i will have to just live with it.
i have tried adjusting the preload with and without the sway link and have put it on the ground with and without sway bar and it is still off.
today i check the spring rates and they are the same. i measured from bolt to current location and still off.
not sure what the problem is, might be something internal as it was sent out for rebuild but it rides fine and adjusts great.
btw anyone getting squeek from the top of their r2 from the rubber bushing on the top?
i am thinking of spraying some silicon inside as its driving me a little nuts
Resurrecting an old thread, but regarding the helper springs: Where can I find block height (or fully compressed height) of some 2.5" options? I found a chart for Swift springs (available in 60 and 65mm), but only see the free length of other options. Eibach has compressed height listed for their "tender" springs, but those have rates starting at 150 lbs. The catalog has nothing but a blank spot where their helper spring compressed height should be listed. Both the Hyperco 4" and 6" "zero-rate" helpers say they compress to 1/4" ... I'm looked for something with a compressed height of 1" in 2.5 ID in order to add an inch to the bump travel of the shock ... (correct me if my thinking is wrong)
Thx!
Thomas
Thx!
Thomas
You don't gain travel with helper springs. It's only to keep the weight loaded on the spring
Depending on your setup i think you can raise the car or install extended top hats for more travel
If you can lower your shock body that will also gain travel since you can lengthen the shock
suzuka san
Jan 10, 2014 05:43 AM
d2van
Jun 26, 2004 04:19 PM
